How to remove Nightshades ? - Mustang Evolution
Old 11-15-2013, 02:53 PM   #1
Slow4V's Avatar
Anyone have a good idea to remove vht Nightshades from tail lamps without messing them up. Thanks
Brake cleaner ?
Gas ?
Old 11-15-2013, 03:03 PM   #2
MidnightBlueGT's Avatar
I know some try paint thinner.
You still got the cobra ones with the ambers? Those are sweet put those on.
Old 11-15-2013, 03:06 PM   #3
Horseplay's Avatar
Originally Posted by Slow4V View Post
Anyone have a good idea to remove vht Nightshades from tail lamps without messing them up. Thanks Brake cleaner ? Gas ?
carb cleaner works perfect. then buff them out and hit them with clear coat
Low2v
Old 11-15-2013, 11:49 PM   #4
qccoles's Avatar
Don't try any chemicals. You risk cracking your taillights, I learned the hard way.
I wet sanded mine with 800 grit and moved up to 2000 grit. And then I used my DA polisher(you can do it by hand too) to work in Meguiars Ultimate Compound. Good as new.
qccoles is offline   Reply With Quote
Old 11-15-2013, 11:56 PM   #5
Goo gone. Works amazingly. That's how Joey18 did it, he even did a video and it looked almost too easy.
Old 11-16-2013, 12:03 AM   #6
qccoles's Avatar
I can co-sign goo gone. But make sure you have enough, you don't want to have to wipe it, then it gets bad.
Old 11-16-2013, 11:05 AM   #7
Roguestang's Avatar
I wet sanded mine when i had vht on them. Looked fine after, but I ended up putting tinted covers on later.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 11-16-2013, 11:49 AM   #8
Screaming Mach's Avatar
+1
Screaming Mach is offline   Reply With Quote
04:40 AM
