Midpipe Question - Mustang Evolution
Old 11-17-2013, 11:36 AM   #1
ty98gt's Avatar
Midpipe Question
I might be picking up a stock h pipe from craigslist soon and I need to know what to look for (bad cats, leaks?) and what else ill need to get it installed on my car.
I bought my car with a catted x on it but ill need the stock pipe for possible smog issues, ect (i live in CA...). My car is a 98 btw, and the pipe I'm going to be looking at came off a 98gt as well
Engine/drivetrain mods: Pro 5.0 Short Shifter, Dragon Plenum-75mm, Accufab TB-70MM, K&N FIPK GEN.2 Air Intake, Bassani Cat Back Exhaust,Bassani Catted X Pipe, 3.73 FRPP Rear Gears,Ford Racing TA Rear Diff Cover,
Bunch of suspension goodies
ty98gt is offline   Reply With Quote
Old 11-17-2013, 12:31 PM   #2
XSlashDashX's Avatar
Originally Posted by ty98gt View Post
I might be picking up a stock h pipe from craigslist soon and I need to know what to look for (bad cats, leaks?) and what else ill need to get it installed on my car. I bought my car with a catted x on it but ill need the stock pipe for possible smog issues, ect (i live in CA...). My car is a 98 btw, and the pipe I'm going to be looking at came off a 98gt as well
If you have a catted mid pipe you should be fine
Old 11-17-2013, 12:37 PM   #3
MidnightBlueGT's Avatar
As long as its catted it should pass but in some states it still doesn't. I know you can get some stock midpipes from junkyards for pretty cheap. Make sure the catalyst is in tact.
Old 11-17-2013, 12:37 PM   #4
Mile high JDF's Avatar
Depends on his emissions regulations. You can still fail if you don't have the correct number of cats.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 11-17-2013, 12:39 PM   #5
In Cali it's best to just keep the stock mid pipe and use that for smog. They can be real pricks about all of that.
Old 11-17-2013, 12:41 PM   #6
Op I would look for the obvious cracks and stuff like that. Also make sure that no particles fall out of the pie if you tip it over
Old 11-17-2013, 12:41 PM   #7
+1 lol cali seems like a communist state.
Old 11-17-2013, 12:50 PM   #8
Yes it is. A lot of catted h midpipes I've looked for will say "WILL NOT PASS CA INSPECTION" and it's usually in caps too lol
KoolPwny is offline   Reply With Quote
Old 11-17-2013, 12:55 PM   #9
ty98gt's Avatar
The previous owner got it to pass with the catted x when he sold it to me, but he said it failed emissions before, so thats why I wanted to get the stock pipe in case I fail when i go for smog soon. Also if i ever decide to sell the car and the next owner wants the stock pipe, it would make things easier
Also the pipe is aluminum and 6 years old, and one cat started rattling so its looking as if it's life might coming to an end soon..
Old 11-17-2013, 12:56 PM   #10
The previous owner got it to pass with the catted x when he sold it to me, but he said it failed emissions before, so thats why I wanted to get the stock pipe in case I fail when i go for smog soon. Also if i ever decide to sell the car and the next owner wants the stock pipe, it would make things easier Also the pipe is aluminum and 6 years old, and one cat started rattling so its looking as if it's life might coming to an end soon..
Passing the sniff test is easy, it's that ****ing visual that fails everyone... If it passes the sniff test why the **** do you need to look at what is done to the car???
Old 11-17-2013, 01:03 PM   #11
ty98gt's Avatar
Exactly, if it passes it passes. It shouldn't make a difference if you "illegally remove factory smog equipment" when its passing the sniffer. California is absolute hell for modded cars
Old 11-17-2013, 01:22 PM   #12
Cars don't even need cats nowadays. They run clean enough.
My friend knows the smog referee of the area, and said one day a guy came in with a Corvette Z06, fully built engine, twin turbos and full straight pipes..... It put out less emissions than a hybrid.
08:29 AM
