Bad Clutch Quad ? - Mustang Evolution
Old 11-17-2013, 03:29 PM   #1
Slow4V's Avatar
Bad Clutch Quad ?
I noticed yesterday when i engage my clutch pedal it doesn't feel normal, also it makes a popping noise that seems to be coming from the plastic quadrant , could it be going out ?
It's also getting hard to put into gear , feels like pedal is not letting me engage correctly
Any suggestions ?
Old 11-17-2013, 03:46 PM   #2
Mile high JDF's Avatar
Have you tried the auto readjust trick? You could try and look at the quadrant while trying to push the pedal and see if you notice any flexing or slipping
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 11-17-2013, 04:00 PM   #3
Slow4V's Avatar
I tried
Old 11-17-2013, 04:25 PM   #4
Slow4V's Avatar
Now it's making loud cracking noise coming from Too of pedal under dash
And won't engage unless pedal is all the way on floor
I grinded 3rd bad
Old 11-18-2013, 07:52 AM   #5
Poke your head under there and look at it... I mean... you can see it pretty easy. Feel your hand under there too.
Buy the MM quadrant and a Fiore micro click adjuster and be done with it. Also hopefully your cable is OEM. If not, you need an OEM cable which MM sells too.
Old 11-19-2013, 01:05 AM   #6
Slow4V's Avatar
Found out it was my cable
It's ripped right after the firewall in the engine bay
Going to ford to get a new one tomorrow
» Members Mustangs
n/a
Diehard
Nadia
Dan93fox
Add your Mustang
04:12 PM
