Strange vibration - Mustang Evolution
Old 11-19-2013, 08:05 PM   #1
04sonicbgt's Avatar
Strange vibration
So when I am backing up/ in between switching gears I have a very loud vibration from the middle/back end of my car. I'm thinking it is a transmission mount but I haven't had a chance to get under it today. Anyone experience this?
Sonic blue 04 GT~~bolt ons- headers, steeda tri ax, hi tech stage 2 cams coming this winter.
04sonicbgt is offline   Reply With Quote
Old 11-19-2013, 08:51 PM   #2
irishn8's Avatar
Theres a differential back there...
Are u turning when u here it? Or just in reverse or clutch in and shifting to first?
Old 11-19-2013, 09:11 PM   #3
04sonicbgt's Avatar
It has happened when turning, and decelerating but it mainly happens when I'm in reverse letting off the clutch and giving it some gas. I read something a minute ago, someone with this same problem and their driveshaft ended up being loose so I'll get under it tomorrow and see if that may be the problem.
Old 11-20-2013, 06:47 AM   #4
04sonicbgt's Avatar
Originally Posted by irishn8 View Post
Theres a differential back there... Are u turning when u here it? Or just in reverse or clutch in and shifting to first?
ok so after driving it this morning it does seem to do it more often when turning, what are you thinking?
Old 11-20-2013, 12:00 PM   #5
irishn8's Avatar
Differential fluid. Probably just needs changing.
Old 11-20-2013, 12:05 PM   #6
irishn8's Avatar
I had kind of a metallic grind/vibration when going around turns sharply. I thought my diff was bad, changed out the fluid and that was it.
If that doesn't do it or if my symptom doesn't match urs then get a friend to replicate the symptom while you listen and watch.
Old 11-20-2013, 12:27 PM   #7
04sonicbgt's Avatar
Thanks, I'll definitely do that and see if it solves my problem!
Old 11-25-2013, 08:42 AM   #8
04sonicbgt's Avatar
Well I figured out it wasn't anything to serious... Both of my exhaust pipes were banging against the frame rail I was surprised those damn things created that much noise/ vibrations. And I just had my exhaust redone about a month ago... Looks like I'll be going back and getting that fixed for free. I was worried, because my differential does have a slow leak :/, going to be getting that fixed soon also.
Old 11-25-2013, 01:16 PM   #9
irishn8's Avatar
Good! Glad u figured it out. Its so hard to diagnose sounds over a forum lol, i would have know right away what that is coz mine does that too. Someday ill git down there and tighten it up...maybe after it falls off or something haha
Old 11-25-2013, 01:45 PM   #10
04sonicbgt's Avatar
definitely but I appreciate your reply and help! Your response did in fact help me diagnose a differential leak!
Old 11-25-2013, 05:46 PM   #11
irishn8's Avatar
Thats really easy to fix too, just open it up, scrape out all the old gasket and put on ATV and close it up (replace fluid obviously)
04:57 AM
