iac valve alternator - Mustang Evolution
Old 11-20-2013, 09:40 AM   #1
04__gt's Avatar
I've replaced the iac valve alternator and this morning when I went to crank the car it took two turns before it would start someone please tell me what's wrong with the money pit today
---------- Post added at 12:40 PM ---------- Previous post was at 12:38 PM ----------
And when I back up and turn to the right something at the front wheels knocks/pops
04__gt is offline   Reply With Quote
Old 11-20-2013, 09:50 AM   #2
tonyd01gt's Avatar
what type of maintenance have you done to the car? is there a miss fire? vacuum leak? popping noise sound like you should check the ball joints and tie rod ends.
tonyd01gt is offline   Reply With Quote
Old 11-20-2013, 11:42 AM   #3
Slow4V's Avatar
Originally Posted by 04__gt View Post
I've replaced the iac valve alternator and this morning when I went to crank the car it took two turns before it would start someone please tell me what's wrong with the money pit today ---------- Post added at 12:40 PM ---------- Previous post was at 12:38 PM ---------- And when I back up and turn to the right something at the front wheels knocks/pops
Sometimes it takes a couple tries to turn on, could be normal ..
Could be anything , only way to know is jack it up and take a look at your suspension bushings / ball joints / tie rods / end links
Old 11-20-2013, 03:19 PM   #4
v8pony's Avatar
Originally Posted by Slow4V View Post
Sometimes it takes a couple tries to turn on, could be normal .. Could be anything , only way to know is jack it up and take a look at your suspension bushings / ball joints / tie rods / end links
Idk if I'd call that normal, something has to be causing it, some mornings it gets In the teens around here, have never had to crank for more than a few seconds to get it to turn over.
2002 5spd GT
Feb 2013 Mustang of the Month
Old 11-20-2013, 05:10 PM   #5
Mfore33's Avatar
Blocked fuel filter or weak fuel pump
Old 11-20-2013, 08:31 PM   #6
cliffyk's Avatar
Did you disconnect the battery for 5-7 minutes while/after installing the new IAC valve? Then after that did you let it idle for at least 15 minutes so the PCM could learn the new idle air trim values?
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
car revving down slowly AgentOrange 1996-2004 Mustang GT 7 01-16-2013 03:39 PM
03 throttlebody briankiel 1996-2004 Mustang GT 26 01-05-2013 04:00 PM
Holley aluminum heads Kenny laird 1979-1995 Mustang GT 3 10-12-2012 11:06 AM
PCV Valve jjsg09 1996-2004 Mustang GT 3 02-08-2012 06:15 AM
07:38 PM
