Help with emissions please - Mustang Evolution
Old 11-25-2013, 04:40 PM   #1
Droski22's Avatar
I changed my front o2 sensors and have dummies on the back, I don't have a check engine light but I'm getting these two codes P0174 (system to lean bank 2) and P0430 (catalyst system efficiency below threshold bank 2) now I don't have any cats but I have the mil dummy plugs on and have changed the both front o2 sensors and cleared it but these keep coming up and I need to pass emissions ASAP please help!!
Droski22 is offline   Reply With Quote
Old 11-25-2013, 05:14 PM   #2
87LX306's Avatar
Well its telling you the drivers side bank of cylinders are running lean also that its not seeing proper emissions drop between bank 2 sensor 1 and bank 2 sensor 2.
Could have a bad simulator on the bank 2 side. Have you hooked up a scan tool for live data?
87LX306 is offline   Reply With Quote
Old 11-26-2013, 10:13 PM   #3
Droski22's Avatar
Originally Posted by 87LX306 View Post
Well its telling you the drivers side bank of cylinders are running lean also that its not seeing proper emissions drop between bank 2 sensor 1 and bank 2 sensor 2. Could have a bad simulator on the bank 2 side. Have you hooked up a scan tool for live data?
the simulators are new and those were off of my buddies scanner I just hope nothing's cracked anywhere?
Old 11-26-2013, 10:40 PM   #4
87LX306's Avatar
Always bad eggs my friend. Id pull live data on the downstreams and see if you can see a difference from bank to bank.
Old 11-26-2013, 11:10 PM   #5
MidnightBlueGT's Avatar
Are you sure theyre turned on? Being tuned for o/r turns them off usually.
Old 11-27-2013, 08:55 AM   #6
cliffyk's Avatar
An exhaust leak before or near the driver side front O2 sensor can cause both those codes...
02:53 AM
