1996 3.8l v6 over heating - Mustang Evolution
Old 11-26-2013, 12:43 AM   #1
Have recently got a 96 mustang and for awhile it was running fine it then started to over heat I checked the coolant and I had ran it dry I filled it up and proceeded to drive and it again was over heating and no hot air coming from heater what could the problem be? Could it be air trapped in the system? Please help!
---------- Post added at 01:43 AM ---------- Previous post was at 01:40 AM ----------
It is also pumping white smoke from the exhaust never did before I filled it up
Shaneme182 is offline   Reply With Quote
Old 11-26-2013, 01:48 AM   #2
Bad news... I think you have a blown head gasket.
Old 11-26-2013, 05:48 AM   #3
mystang50's Avatar
x2
check your oil, if its white or or is not black, then yup...
Old 11-26-2013, 08:03 AM   #4
Is your exhaust blowing white smoke?
Thenervemann is offline   Reply With Quote
Old 11-26-2013, 08:43 AM   #5
MidnightBlueGT's Avatar
Wrong section.
« Injectors | Mystery »
07:58 PM
