Bullitt's next mods? - Mustang Evolution
Old 11-26-2013, 07:10 PM   #1
Ok so since I got a somewhat of a job in going to have a tiny bit of money for upcoming mods. My dilema is that I feel the car is pretty slow (Had a hard time passing a truck on the freeway).
So I planned for cams and gears, but I do like to autocross and take corners a lot. Should I work on the power of the car, or should I work on suspension? I'm really stuck on this one.
Old 11-26-2013, 07:27 PM   #2
Get a driver mod and/or gt
---------- Post added at 06:24 PM ---------- Previous post was at 06:24 PM ----------
Lol jk
Save up for gears they're bad *** makes passing people in the highway a breeze and fun as hell
---------- Post added at 06:25 PM ---------- Previous post was at 06:24 PM ----------
Hey let's see how many times ME will update my original post
---------- Post added at 06:25 PM ---------- Previous post was at 06:25 PM ----------
Kool I think I'm gonna go for a "post added" record!
Besides gears get some exhaust work
---------- Post added at 06:26 PM ---------- Previous post was at 06:25 PM ----------
If you have exhaust work get some intake stuff
---------- Post added at 06:26 PM ---------- Previous post was at 06:26 PM ----------
If you get a whole lotta money to blow get some trick flow heads for your 2v
^^thats the less traveled route
---------- Post added at 06:27 PM ---------- Previous post was at 06:26 PM ----------
But only cuz the price otherwise they're still pretty bad ***
---------- Post added at 06:27 PM ---------- Previous post was at 06:27 PM ----------
But I'm gonna have to say gears go 4.10 or go home !!!
KoolPwny is offline   Reply With Quote
Old 11-26-2013, 07:40 PM   #3
Clink's Avatar
Someone went full ******....
Get gears OP, and I'm personally not going to make my car faster until the suspension is tightened up and lowered some.
Old 11-26-2013, 07:42 PM   #4
MidnightBlueGT's Avatar
Gears, tuner, suspension mods.
Old 11-26-2013, 07:45 PM   #5
If I do it, I'm going to get gears and cams at the same time. But my dilema was, should I spend it on suspension instead? If I focus on suspension too much gearing will make it easier to break loose in corners.
Old 11-26-2013, 07:46 PM   #6
Originally Posted by Clink View Post
Someone went full ******.... Get gears OP, and I'm personally not going to make my car faster until the suspension is tightened up and lowered some.
Old 11-26-2013, 07:48 PM   #7
personally my car doesn't break the tires loose THAT bad where I'm like"OMFG I need to get this suspension ASAP" I don't think you'll have anything to worry about for a while
Old 11-26-2013, 08:00 PM   #8
Fat pony
Fat Pony is offline   Reply With Quote
Old 11-26-2013, 08:03 PM   #9
Good advice ^
Old 11-26-2013, 08:12 PM   #10
I don't mean suspension to keep grip, I mean suspension to cut corners like subies
Old 11-26-2013, 08:20 PM   #11
ah I see sorry can't help u there
Old 11-26-2013, 08:23 PM   #12
Mile high JDF's Avatar
Hell slam it and get a good alignment and Subies shouldn't be able to keep up much if it's a tight course. I vote suspension
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 11-26-2013, 08:28 PM   #13
I really don't know, cause I like to come onto the highway like a bat out of hell, but I love cutting corners.
Old 11-26-2013, 08:35 PM   #14
I know I'm in the minority on here, I'd rather take turns than go fast in a straight line
Old 11-27-2013, 01:13 AM   #15
xhgwx's Avatar
Gears.
Soccer do gears. You'll never look back, of course mine is stock but I've never driven a car as fast as this ****in termi, that torque feel is amazing
xhgwx is offline   Reply With Quote
Old 11-27-2013, 01:42 AM   #16
Tyoung68's Avatar
I put sway bars on my car and it made a world of difference depending on how tired your cars suspension is id start there theres no point of having all the power in the world but no able to get it down
Old 11-27-2013, 09:44 AM   #17
badsheep5.0's Avatar
I would say pick up some eibach sportlinepro lowering springs man I did and it courners so much better wth just that I wanna so some more suspension work but next I am doing cold air intake throttle body and then maybe gears
badsheep5.0 is offline   Reply With Quote
Old 11-27-2013, 11:08 AM   #18
I've been spending my time and money on restoring my car. A "rolling" restoration, if you will.
Both of our cars have similar miles, so I imagine that the same things are worn out on your car as were on mine.
I just took the car on it's first long drive after completely rebuilding the front end and replacing the struts and shocks and WOW!!! What a difference! The damn car ALMOST drives itself. And it was about a second faster at the autocross. All stock parts.
Same thing with the engine... I did a, fairly, "major" tune up, replaced coils, IAC, 02 sensors PCV valve , cleaned everything, etc.
I noticed at the autocross, that both of our cars have the same "hot start" problem after a short "heat sink". Probably a fuel delivery problem that we'll need to work out.
Other than the shocks and struts, and the tires, all the parts that I used were Motorcraft.
There's quite a bit of room for improvement by just putting our cars back to "as new" condition.
None of that was as fun as actually "modding" the car, but, now I have a pretty good platform to build on should I ever find it necessary to add any high performance goodies.
You already know that the gears will be the "best bang for your buck"...
Old 11-27-2013, 11:39 AM   #19
escottcarp's Avatar
If I had trouble passing a truck, I'd check my engine, ie.. Compression, plugs, COPs. I'd check brakes to see if one is sticking.
It would be good to determine your acceleration problem and fix it before doing other expensive mods.
escottcarp is offline   Reply With Quote
Old 11-27-2013, 05:07 PM   #20
Slow4V's Avatar
Ok so since I got a somewhat of a job in going to have a tiny bit of money for upcoming mods. My dilema is that I feel the car is pretty slow (Had a hard time passing a truck on the freeway). So I planned for cams and gears, but I do like to autocross and take corners a lot. Should I work on the power of the car, or should I work on suspension? I'm really stuck on this one.
Current mods ?
Old 11-27-2013, 05:12 PM   #21
Originally Posted by Slow4V View Post
Current mods ?
+1
true forgot to ask this
Old 11-27-2013, 06:40 PM   #22
Roguestang's Avatar
Sounds like youre stock now, but a list of mods would be good too. Gears sre going to be the best bang for your buck. Dont waste your money on cams just yet. Your gains aren't gonna be enough to warrent the 1k+ you'd spend on parts and labor unless your FI, and even then.
Suspension is key here too. On the low end some sub frame connectors, LCA's, and lowering springs will be a great difference from stock. On the high end, you can spend that money for cams on the suspension like an MM suspension kit, and you'll cut corners like the CEO of a hedge fund company. Of course don't forget a good set of tires goes a loooong way too.
And lastly a tune would be the third thing I'd get. And by tune, I mean dyno tune. You could also look at stripping any unnecessary weight out too.
I remember reading a few years ago about a guy who did full suspension, and stripped interior on a 99-04 2v and ran 12's. He was also an amaizing driver too.....lol
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 11-28-2013, 12:29 AM   #23
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
Hard choice. But I vote suspension over power if you plan on doing much more autox.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 11-28-2013, 09:37 AM   #24
Originally Posted by escottcarp View Post
If I had trouble passing a truck, I'd check my engine, ie.. Compression, plugs, COPs. I'd check brakes to see if one is sticking. It would be good to determine your acceleration problem and fix it before doing other expensive mods.
It wasn't necessarily like that, but coming into the freeway around 40 he flew past me so I gunned it. I just didn't pass him as quickly as it feels like a Mustang should.
---------- Post added at 08:37 AM ---------- Previous post was at 08:35 AM ----------
Current mods ?
BAMA 91 Tune and an MGW, and being a Bullitt it came with the better intake as well as UDPs.
Old 11-28-2013, 09:42 AM   #25
Oh and it came with upgraded shocks and struts, Subframes, and springs, not to mention the 13" Cobra brakes.
Old 11-28-2013, 09:48 AM   #26
2300turboford's Avatar
Thought you had a prochamber mid pipe
Old 11-28-2013, 09:52 AM   #27
If you count that towards performance I do lol
Old 11-28-2013, 11:10 AM   #28
Slow4V's Avatar
I say full exhaust / 373 gears / TB next
Old 11-28-2013, 11:14 AM   #29
Full exhaust, 4.10's, tb :p
Old 11-28-2013, 11:34 AM   #30
Tyoung68's Avatar
I say suspension first
Old 11-28-2013, 03:08 PM   #31
Already have full exhaust and have a good intake with the same oval TB from the 96-98 Cobra.
Old 11-28-2013, 03:17 PM   #32
Slow4V's Avatar
Then I suggest selling the car and getting a 4V mustang
Old 11-28-2013, 03:42 PM   #33
The Bullitts came with the intake and twin cobra throttle body
Old 11-28-2013, 04:02 PM   #34
I'm probably going to mod it and run it till the engine goes, then swap it out for something better.
---------- Post added at 03:02 PM ---------- Previous post was at 03:01 PM ----------
Yup, same one that the 96-98 Cobras use.
Old 11-28-2013, 05:18 PM   #35
TylerJanocha21's Avatar
Is personally go with gears and suspension but that's my opinion
TylerJanocha21 is offline   Reply With Quote
10:02 PM
