Help!!! - Mustang Evolution
Old 11-27-2013, 08:39 AM   #1
1lowGT's Avatar
Help!!!
Who wants to help me install under drive pulleys?? Not literally just help me on here. Pictures would be sweet. I got steeda under drive pulleys and I need help installing I don't have internet to search. Help would be appreciated!
Old 11-27-2013, 08:47 AM   #2
Roguestang's Avatar
You will need a pully puller for taking off the stock crank pully, only four bolts hold the water pully, and IF your doing the alternator you'll need an impact gun to get that one off and on.
---------- Post added at 11:47 AM ---------- Previous post was at 11:46 AM ----------
Also don't forget to take the serpantine belt off....lol
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 11-27-2013, 08:48 AM   #3
1lowGT's Avatar
Okay so do I need the alternator pulley? I see yes and no. What's the difference?
Old 11-27-2013, 08:56 AM   #4
1lowGT's Avatar
Is the torque wrench to tighten everything down afterwards? Cuz I don't have one right now so I'll have to go grab one.
Old 11-27-2013, 09:11 AM   #5
87LX306's Avatar
Hit up your local Autozone. They have the harmonic balancer puller/installer as well as torque wrench both available in their loan a tool program. Pay for them upfront and get ALL of your money back including tax once your done.
87LX306 is offline   Reply With Quote
Old 11-27-2013, 09:21 AM   #6
Roguestang's Avatar
No, you don't absolutely need the alternator pully. You won't notice a difference with it on with the other UDP's anyways.
Old 11-27-2013, 12:37 PM   #7
1lowGT's Avatar
So should I put it on? And I need help knowing which pulley goes where
Old 11-27-2013, 12:49 PM   #8
Jsansom's Avatar
The biggest one is the crank pulley that goes at the bottom.. The medium one goes right above the crank pulley the water pump I believe and the smallest one is the alternator pulley. U don't need that one so don't do it.. These three pulleys make line straight up and down u will see it when u look under the hood..
Jsansom is offline   Reply With Quote
Old 11-27-2013, 12:57 PM   #9
Roguestang's Avatar
You could save yourself the time and need for air tools by not using the alternator pully. Each pully had a different way to bolt to your car. And they look similar to the stock ones, just a little smaller or bigger.
Water pump pully goes on with 4 small bolts.
Crank pulley goes on with one big bolt, and is ribbed (for your pleasure).
Alternator pulley is the smallest of them all, and goes one with one big bolt.
Old 11-27-2013, 01:33 PM   #10
1lowGT's Avatar
Old 11-27-2013, 01:34 PM   #11
1lowGT's Avatar
Which one of those is the water pump pulley
Old 11-27-2013, 01:39 PM   #12
1lowGT's Avatar
Gasket sealer for the water pump bolts?
Old 11-27-2013, 01:48 PM   #13
Roguestang's Avatar
Bottom one with the four bolt holes is the water pump (you labeled it as crank). The middle one looks like the crank, but from my phone its too dark. There is only one way they would go on, once you get the stockers off, you'll see.
---------- Post added at 04:45 PM ---------- Previous post was at 04:44 PM ----------
No, it doesn't protrude Into the pump at all.
---------- Post added at 04:46 PM ---------- Previous post was at 04:45 PM ----------
From your picture:
Top: alternator
Middle: crank (is that a piggy back style?)
Bottom: water pump
---------- Post added at 04:48 PM ---------- Previous post was at 04:46 PM ----------
Wish you had internet access, evem from your phone or something. Thay way you could get the instructions from steeda. Or atleast a write up
Old 11-27-2013, 01:51 PM   #14
1lowGT's Avatar
I got Internet on my phone but just can't search very much cuz I got ****ty service. What's gasket maker for?
---------- Post added at 02:51 PM ---------- Previous post was at 02:49 PM ----------
I can't tell a way to see if it's piggy back or not.the guy said they were steeda but there no name or numbers on them so idk
Old 11-27-2013, 01:58 PM   #15
Roguestang's Avatar
Ok, I just looked at the steeda 01-04 udp, and the crank pulley has some kind of harmonic balancer on it too. Keep in mind the crank pulley has a key hole on it, so there is only one way it'll go on.
---------- Post added at 04:58 PM ---------- Previous post was at 04:56 PM ----------
Gasket maker would be for like the corners im between gaskets (corners) to create a tight seal, some use it around water pumps and stuff, but you shouldn't need any at all.
Its not a piggy back, Just different than mine (99-00 and bbk's)
Old 11-27-2013, 02:00 PM   #16
1lowGT's Avatar
Perfect there it is. And any idea of what specs to tighten these down to?
Old 11-27-2013, 02:10 PM   #17
Roguestang's Avatar
I'm looking now bro. I just used an impact gun to be honest. Oh and I forgot to add, no gasket sealer needed, but you could put some blue locktite on the water pump bolts. Just an fyi. I didn't, and Its been fine for 5 years....lol
Still looking for specs just in case.....
---------- Post added at 05:10 PM ---------- Previous post was at 05:05 PM ----------
From Steeda instructions on crank pulley:
1. Torque bolt to 66 lb-ft.
2. Loosen bolt one full turn
3. Torque bolt to 37 lb-ft.
4. Tighten bolt an additional 90 degrees.
Old 11-27-2013, 02:15 PM   #18
Roguestang's Avatar
And a quick tip:
IIRC on the water pump, barely loosen the bolts before you take the belt off. And put your car in gear too. Once belt is off, go ahead and fimish taking the pullwy out. For the new pulley, put it on and hand tighten the 4 bolts first. Then once its flat against the pump, put your belt back on, and tighten them down after. Other wise you'll be fighting the pulley from spinning.
Old 11-27-2013, 02:19 PM   #19
1lowGT's Avatar
Any belt assembly help?
Old 11-27-2013, 02:30 PM   #20
Roguestang's Avatar
Well use a 3/8 wrench or breaker bar on the idler pulley which is heavy spring loaded. Pull the idler pilley up to swing it up for slack, then pop the belt off. Just make a rendering of the belt routing so you know how it goes back on.
Old 11-27-2013, 02:55 PM   #21
1lowGT's Avatar
Any advice on getting the HB off this bolt is too long looks like
Old 11-27-2013, 03:09 PM   #22
Roguestang's Avatar
I don't follow what you mean? What bolt? What's HB?
Old 11-27-2013, 03:32 PM   #23
1lowGT's Avatar
Harmonic balancer. And on the puller bolt
Old 11-27-2013, 03:44 PM   #24
Roguestang's Avatar
Well you'll need the pulley puller for it. That will attach to the crank pulley with three bolts, anad should be a 3/8 ratchet to back it out. You should have clearance, but it could be tight. And best to get it from under the car. As for install the new one should shimmy on. Might need to tap it slightly to seat, but the torque instructions from steeda will make sure it sits flush.
Old 11-27-2013, 04:17 PM   #25
Roguestang's Avatar
Oh and also, the 4.6's were internally balanced so they technically don't have a "harmonic balancer" like a pushrod 5.0 would.
Old 11-27-2013, 04:47 PM   #26
1lowGT's Avatar
Okay so are is the crank bolt left hand threaded or normal
---------- Post added at 05:47 PM ---------- Previous post was at 05:45 PM ----------
How does the crank pulley go on does it just slide on?
Old 11-27-2013, 04:59 PM   #27
Roguestang's Avatar
Normal thread. And like I stated the new one should just shimmy on, but you might need to tap it alittle evenly to get it flush.the torque sequence will set it completely
Old 11-27-2013, 08:27 PM   #28
H.Doofenshmirtz's Avatar
Region: Australia
I dont know if this will pull up on your phone, got this from serpentinebeltdiagrams-dot-com and they claim the links are for mobile users
Vin X or H:
http://serpentinebeltdiagrams.com/wp...stang-4-6L.jpg
Vin Y or V:
http://serpentinebeltdiagrams.com/wp...ang-4-6L-2.jpg
hth
No work and no pony makes Doof a dull boy...
H.Doofenshmirtz is offline   Reply With Quote
03:28 PM
