driveshaft rubbing - Mustang Evolution
Old 11-27-2013, 05:47 PM   #1
Clean98 Gt's Avatar
driveshaft rubbing
I have a 98 gt. While driving or coasting there is a grinding noise coming from driveshaft it is rubbing against the yoak anyone know why please help. Thanks.
Clean98 Gt is offline   Reply With Quote
Old 11-27-2013, 06:03 PM   #2
I'd stop driving it IMMEDIATELY !!!
You need to remove the driveshaft and find out what is going on.
It's possible that you have a bad U-Joint...
Old 11-27-2013, 06:07 PM   #3
Roguestang's Avatar
+1
Probably a bad U-Joint. If that drive shaft breaks while going down the road, well hopefully you'll still look good enough for an open casket viewing.
Safety first!
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 11-27-2013, 09:02 PM   #4
d_1212's Avatar
Is it constant or just when ur slowly starting to go forward? I feel like I might have the same issue but it only does it when I'm taking off n as soon as I get up to a decent speed it stops. If u figure it out pls update! My car is off the road for winter but I want to get it fixed as soon as I put if back on the road
d_1212 is offline   Reply With Quote
Old 11-28-2013, 05:34 PM   #5
Clean98 Gt's Avatar
Its a constant grind. Once the rear wheels are moving it starts. I car has a 1.5 inch drop..
Old 11-28-2013, 08:01 PM   #6
Don't drive it. Put your car on a lift and rotate your wheels manually to see what is going on.
12:01 AM
