2001 Cobra throwing codes - Mustang Evolution
Old 11-29-2013, 11:44 AM   #1
Slow4V's Avatar
My uncle has a 2001 cobra
LTs / O\R X / 62mm TB / CAI / SCT Tuner / 410s
Stage2 TR3650 / Exedy Clutch
After he replaced his transmission he noticed he was getting Bank 1 rich / lean codes , I checked his harness to see if it was pinched and nothing.. Says the Rpms jump up and down when driving and throws black smoke, and wastes a lot of gas.
This happened a time before when they re-did the heads , it ended up being a pinched harness
I did not see anything pinched while I was under there. Still clueless
He replaced the O2 sensors last year , IAC, TPS , cleaned MAF ..
Any suggestions
Old 11-29-2013, 06:34 PM   #2
1996mustang's Avatar
Only on bank 1? Possible injector leak could cause a misfire and black smoke due to fuel dumpage into the cylinder. If its the passenger side i would also look for a vacuum leak just in case not sure what all was involved if only a tranny swap but just imputing. Possible not a pinched harness but a exposed harness wire grounding out at times under vibration of the car causing it to touch a metal area.
07:23 AM
