Clutch Cable - Mustang Evolution
Old 12-02-2013, 04:56 PM   #1
cmonro2's Avatar
Clutch Cable
I have a 03 cobra. Factory clutch cable. How do i know if the cable is too tight. It has the adjustment but i dont want to get it too tight and it break. When i got the car about 2months ago i had to adjust it and it shifted fine . now its getting hard to put into gears again. Anyone got any suggestions on what i need to do?
cmonro2 is offline   Reply With Quote
Old 12-02-2013, 05:32 PM   #2
Roguestang's Avatar
Congrats on the Termi!
If you haven't already put up some pics!
When you say its too tight, is it slipping?
Why did you have to adjust it to begin with?
I think Slow4V had a similar issue a while back (don't qoute me on it though), and he replaced it with an oem clutch cable and everything was back to normal.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 12-02-2013, 05:38 PM   #3
Just use the factory adjustment to get it back where you want it.
When you get sick of that just buy a firewall adjuster and quadrant. Aftermarket clutches are actually lighter...
Old 12-02-2013, 06:55 PM   #4
cmonro2's Avatar
I was saying how do you know if the cable is too tight. when i put it in gear it doesnt want to go into the gears some. I adjusted it with the adjustment on the clutch pedal. It worked fine for about a couple of weeks. Now its doing the same thing again. Do i need to go and adjust the cable again. I just didnt want to keep adjusting and then the cable be too tight and then break. And how many times should i have to adjust it?
Old 12-02-2013, 08:00 PM   #5
How could it possibly be tight enough to break? Think about it, if it was tight enough to break the pedal would be all the way on the floor and you'd have no pedal play at all.
Yank up on the pedal again or it might be time to get a new OEM cable. Again, an OEM cable, NOT a parts store or Rockauto special. Maximum Motorsports sells a kit that is their quadrant, an OEM cable and a firewall adjuster.
Old 12-04-2013, 05:34 PM   #6
cmonro2's Avatar
Thanks. I ordered my clutch cable kit today at Maximum Motorsports with thier quadrant, cable and firewall adjuster. They said its back ordered and should be shipped out by the 13th.
Old 12-04-2013, 05:47 PM   #7
xhgwx's Avatar
Do NOT use anything other than the OEM cable all other cables have been proven to fail very quickly.
xhgwx is offline   Reply With Quote
Old 12-04-2013, 06:04 PM   #8
Roguestang's Avatar
They use an oem cable with thier kit. Its high quality.
Old 12-04-2013, 06:16 PM   #9
xhgwx's Avatar
Ok good, wasn't sure because it is aftermarket.
As long as it's the OEM.
My buddy with a GT went thru 3 after market cables in a year. They all snapped.
Old 12-04-2013, 06:34 PM   #10
Roguestang's Avatar
Dang, you'd think after one breaking he would learn! Lol
Old 12-04-2013, 07:32 PM   #11
Slow4V's Avatar
I went OEM last month
Greatest choice ever
Old 12-04-2013, 07:36 PM   #12
xhgwx's Avatar
I love ur mach....
Old 12-04-2013, 07:44 PM   #13
Slow4V's Avatar
I love ur mach....
Thanks man your cobra is pretty sweet , in jealous
Old 12-05-2013, 12:33 PM   #14
Yep, says right in the item description it is OEM and it even has a diagram of what an OEM cable looks like vs a Napa special.
Old 12-05-2013, 12:41 PM   #15
Roguestang's Avatar
When I swapped my AOD out of my Fox for the T-5, I went with thier kit. I've still got the original in my New Edge, but when it starts giving me issues, I'll be doing the same thing.
Old 12-23-2013, 07:26 PM   #16
cmonro2's Avatar
I replaced the cable and clutch quadrant and the firewall adjustment and everything works great now.
Old 12-23-2013, 10:32 PM   #17
Roguestang's Avatar
Good to hear
08:03 PM
