CIA - Mustang Evolution
Old 12-03-2013, 06:43 PM   #1
Davesorl04gt's Avatar
CIA
Is there an easer way to get that dad blame filter on the end of a CIA when it is in the fender?
Davesorl04gt is offline   Reply With Quote
Old 12-03-2013, 07:10 PM   #2
1996mustang's Avatar
From under the car....i used to just stick a small stubby flat head so i can loosen the clamp pull off the filter clean it then put it back. Never really had much on an issue doing it that way
Old 12-03-2013, 07:12 PM   #3
UltArc's Avatar
Throw away your cell phone and get a foil hat. That'll keep the CIA away.
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline   Reply With Quote
Old 12-03-2013, 07:35 PM   #4
Maybe next time I'll try jacking the car up higher. Took longer to get the filter on than to install the whole thing. Probably need to lose about 70 pounds also.
Old 12-03-2013, 10:44 PM   #5
KoolPwny is offline   Reply With Quote
Old 12-04-2013, 11:32 AM   #6
I had a BBK CAI in my 95 that had the filter in the fender. Just go up from underneath, get a stubby screwdriver to tighten it and good. Now I can't speak to the CAI you got, I'm guessing it is the SR that was $60 on the Black Friday sale. I just know on the BBK it was easy.
Old 12-04-2013, 12:22 PM   #7
MidnightBlueGT's Avatar
You cant get away from Stan. He's too good
Old 12-04-2013, 07:46 PM   #8
Is there any tricks in getting a roll around jack under the car, driving up on blocks of wood, ect? I'm not a small guy and need to get it as high as possible. Or do I need to get a smaller jack?
Old 12-04-2013, 09:29 PM   #9
I personally used roll on ramps ...... i use them often for oil changes and such. You can use a small jack to jack up the passenger side since the cai lies within that fender. All you gotta do is lift it enough to get a hand in there from under the car to either take off or put in the filter. But if you choose to do it well use a jack and jack stands....dont rely on only a jack since jacks have a tendency of possibley loosing hydraulic pressure and they may creep down on you.
Old 12-05-2013, 09:26 AM   #10
Thanks for the tips everyone.
Old 12-05-2013, 12:41 PM   #11
You don't need anything you just reach up and stick it on the end of the CAI tube. Then go in with a stubby screwdriver and tighten it up. I did the filter in my 95 religiously. Just lay on your back and reach up under the fender liner in the front. Takes a little maneuvering but nothing crazy.
Old 12-05-2013, 01:02 PM   #12
Thanks, I was using a nut driver. Not much room up in those finders. Will try something smaller next time.
Old 12-07-2013, 07:22 PM   #13
2002VertGT's Avatar
bahahahaha
4.10 Gear/RPM thread
11:20 AM
