96 GT brake upgrade - Mustang Evolution
Old 12-04-2013, 05:50 AM   #1
96NYCGT's Avatar
Send a message via AIM to 96NYCGT
96 GT brake upgrade
Want to know if this mod will work
I want to upgrade my 96 GT brake by using a 2004 GT brakes system such as caliper brake, pad, rotor, and stainless steel hose line. I know it's not a really big upgrade but cobra brake is just not in my budget.Will I run in to any fitment issue.
96NYCGT is offline   Reply With Quote
Old 12-04-2013, 06:38 AM   #2
Slow4V's Avatar
Originally Posted by 96NYCGT View Post
Want to know if this mod will work I want to upgrade my 96 GT brake by using a 2004 GT brakes system such as caliper brake, pad, rotor, and stainless steel hose line. I know it's not a really big upgrade but cobra brake is just not in my budget.Will I run in to any fitment issue.
Isn't it the same exact set up ?
Old 12-04-2013, 06:53 AM   #3
Nope the 99-up cars had a dual piston caliper setup on GT size brakes. No there will not be any clearance issues IIRC its a direct bolt in. It is a good upgrade from stock but I distinctly remember my first thought when test driving 04 Mustang GTs for my buddy who was just learning stick was "wow this does NOT stop as well as my Cobra". Still way better than my 91 did though...
FWIW the Cobra brakes on my 98 have possibly already saved my life. If I'd have had the stock brakes I would have had a VERY bad wreck, probably with the 99-04 GT stuff too.
Old 12-06-2013, 01:18 PM   #4
96NYCGT's Avatar
I should be install everything sometime next weekend because I'm still looming for some 04 stainless steel brake line at a low $
Old 12-06-2013, 02:21 PM   #5
Roguestang's Avatar
I've got Russells on mine. I think they were brand new for like 100 bucks, for the fronts.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 12-07-2013, 12:47 PM   #6
Its definitely an upgrade to the stock 96 brakes, but the Cobra brakes are so worth it!
302 Stroker TFS Heads + Cams 11.2:1 CR
327/352 hp/tq
8111870 is offline   Reply With Quote
Old 12-07-2013, 12:57 PM   #7
They didn't come with ss lines.
Just buy any of the kits out there, I could tell a difference on my cobra after doing it.
Old 12-14-2013, 02:57 PM   #8
96NYCGT's Avatar
Just complete and everything fit like A gloveClick image for larger version
Name:	ImageUploadedByMustang Evolution1387058194.699683.jpg
ID:	141588Click image for larger version
Name:	ImageUploadedByMustang Evolution1387058206.815631.jpg
ID:	141589Click image for larger version
Name:	ImageUploadedByMustang Evolution1387058217.182228.jpg
ID:	141590Click image for larger version
Name:	ImageUploadedByMustang Evolution1387058225.899356.jpg
Old 12-14-2013, 03:15 PM   #9
Looks good, you will notice a big difference but the pedal will be a little stiff with the GT master cylinder, not a big deal, just push harder lol. I had to emergency stop in mine over the summer and that thing came down from 60mph REAL quick. I've got the Cobra/Bullitt/Mach setup on all 4 corners though, to do the rears you have to pull the axles and install new mounting brackets but seeing as most of the braking is done up front its not really needed.
Old 12-14-2013, 03:20 PM   #10
96NYCGT's Avatar
I only take it around the block for now it's snowing about 3 to 4 inch right now maybe Monday I'll put it thru some testing
Old 12-14-2013, 03:54 PM   #11
9tee7pony's Avatar
I should really look into doing this, maybe the cobra setup instead. People really seem to like to cut me off. If I had done it I probably wouldn't have hit that deer either.
9tee7pony is offline   Reply With Quote
Old 12-14-2013, 04:13 PM   #12
Mile high JDF's Avatar
The Cobra brakes are definitely an upgrade from GT brakes, I noticed a pretty major difference in braking especially from high speeds
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-14-2013, 04:23 PM   #13
96NYCGT's Avatar
I'll do the rear brakes when the weather get a little better the cold make working harder Click image for larger version
Name:	ImageUploadedByMustang Evolution1387063282.722734.jpg
Old 12-14-2013, 08:18 PM   #14
Roguestang's Avatar
I'll leave this here......
09:29 AM
