supercharged 2002 gt - Mustang Evolution
Old 12-05-2013, 09:58 PM   #1
I have 373 gears, shorty headers, x pipe, 3 chamber flowmasters,stage 2 cams, stage 2 clutch, 75 mm throttle body, aluminum intake manifold, and a stage 2 short shifter. Stock cylinder heads and engine block. Can this car handle supercharger?
faceman773 is offline   Reply With Quote
Old 12-05-2013, 10:14 PM   #2
Slow4V's Avatar
Ofcourse
Any car practically can
Old 12-05-2013, 10:15 PM   #3
how many miles are on your car?
KoolPwny is offline   Reply With Quote
Old 12-05-2013, 10:22 PM   #4
150,000. I'm just wondering if anything else needs to be swapped out before the change because I was reading up on it and swapping out certain parts was a must.
---------- Post added at 11:22 PM ---------- Previous post was at 11:19 PM ----------
I also had the trans and heads rebuilt. Everything except the block itself has been redone.
Old 12-05-2013, 10:26 PM   #5
MidnightBlueGT's Avatar
Change spark plugs, and upgrade fuel pump and injectors. Might want to do a compression and leak down test too
Old 12-05-2013, 10:33 PM   #6
Roguestang's Avatar
+1
A compression test will tell you how well your cylinders are doing. If it all checks out, get a Vortech (kit or piece it together) and get a good dyno tune. With a good tune it'll be very reliable assuming you don't increase the PSI past 10.....lol
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 12-06-2013, 01:46 AM   #7
ColeJohnson's Avatar
Originally Posted by Roguestang View Post
+1 A compression test will tell you how well your cylinders are doing. If it all checks out, get a Vortech (kit or piece it together) and get a good dyno tune. With a good tune it'll be very reliable assuming you don't increase the PSI past 10.....lol
And at the same time I'd go ahead and replace the gaskets on the engine and upgrade to ARP hardware... That is if you don't just go ahead and do a rebuild.
2016 Comp Orange GT (current)
Old 12-06-2013, 06:55 AM   #8
Roguestang's Avatar
Absolutely agree; if your gonna rebuild I would do those things as well. But sounds like the OP wants to know if his engine will handle boost as is. Thats where tune is key
03:50 PM
