Bouncy - Mustang Evolution
Old 12-07-2013, 11:07 AM   #1
Slow4V's Avatar
Bouncy
I've been noticing my ride is getting a bit bouncy
And is kind of rough..
I've had my Tokico HP struts and shocks for about 2 years,
And cut springs..
Any ideas ?
And when I hit bumps or pot holes it hits hard
Old 12-07-2013, 11:11 AM   #2
alrefire's Avatar
You need to match your struts/shocks to your springs. Your struts/shocks probably wore out quickly.
Old 12-07-2013, 11:33 AM   #3
How much tread is left on your tires?
It's surprising how much worse the ride gets as the tires wear out.
Old 12-07-2013, 11:35 AM   #4
I keep hearing people mention this and have no clue what you are referring to...
Old 12-07-2013, 11:42 AM   #5
Me too.
I can understand the matching the struts and shocks to the springs but the wearing out part stumps me as well.
I think that Slow has stock springs that have been cut.
Old 12-07-2013, 11:47 AM   #6
Originally Posted by straybullitt
Me too.
What are people matching? That's what I am confused about.
Old 12-07-2013, 11:58 AM   #7
Mile high JDF's Avatar
The manufacturer sets a spring rate and how low the struts can handle on a car. I know Maximum Motorsports has a couple charts showing the various recommendations for the struts and shocks they sell
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-07-2013, 12:00 PM   #8
alrefire's Avatar
Well 2 things mainly
1)try to stick to the same brand
2) make sure the shock/strut is designed for a certain length spring/#
stock shocks/struts aren't designed for cut or aftermarket springs (with a big drop <1) that's why they wear out quickly.
Old 12-07-2013, 12:02 PM   #9
Correct
---------- Post added at 01:02 PM ---------- Previous post was at 01:01 PM ----------
What does brand have to do with anything. I have two different spring brands on my car with another shock/strut brand. Best riding mustang i've been in.
Old 12-07-2013, 12:06 PM   #10
alrefire's Avatar
Correct ---------- Post added at 01:02 PM ---------- Previous post was at 01:01 PM ---------- What does brand have to do with anything. I have two different spring brands on my car with another shock/strut brand. Best riding mustang i've been in.
Parts that are R&D together stick together 👍
Old 12-07-2013, 12:39 PM   #11
The spring rates are what you're trying to match with the shocks and struts. I think that you need to buy a complete suspension kit to really get a good match. I had some Monroe's on my Bullitt from the PO where the valving was way to light for the springs. Most manufacturers just sell one part# for each car, usually dependent on the weight of the vehicle. This is where adjustable shocks and struts come into play and allow you to adjust the valving to match the set-up on the car.
I'm not sure why people are saying that mismatched springs and struts wear out faster though. You're still driving over the same bumpy roads...
Old 12-07-2013, 02:14 PM   #12
Slow4V's Avatar
Originally Posted by straybullitt View Post
How much tread is left on your tires? It's surprising how much worse the ride gets as the tires wear out.
Tires are about 6 months old
Old 12-07-2013, 02:24 PM   #13
Lol. I completely wore out a set in 6 months.
How many miles are on your car?
Have the strut bushings ever been replaced?
Old 12-07-2013, 02:26 PM   #14
alrefire's Avatar
The spring rates are what you're trying to match with the shocks and struts. I think that you need to buy a complete suspension kit to really get a good match. I had some Monroe's on my Bullitt from the PO where the valving was way to light for the springs. Most manufacturers just sell one part# for each car, usually dependent on the weight of the vehicle. This is where adjustable shocks and struts come into play and allow you to adjust the valving to match the set-up on the car. I'm not sure why people are saying that mismatched springs and struts wear out faster though. You're still driving over the same bumpy roads...
I'm not saying mismatched as in different brands. When I say mismatched, I'm referring to wrong springs for the wrong strut/shocks
The reason I'm recommending the same brand, however, is because it takes out the guesswork. Making it easier for most people to pick something and go.
09:52 PM
