Bamaperformance tuner - Mustang Evolution
Old 12-07-2013, 03:16 PM   #1
TheWitness's Avatar
Has anyone had any trouble with their bama tuner? It's making my 04 gt idle at about 1500rpm until I come to a complete stop, even when the car isn't in gear.
TheWitness is offline   Reply With Quote
Old 12-07-2013, 03:22 PM   #2
Mile high JDF's Avatar
Are you sure it's your tune that's causing an issue? Usually a high idle while coasting and sitting still is caused by the idle for control
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-07-2013, 03:24 PM   #3
TheWitness's Avatar
Originally Posted by JDF View Post
Are you sure it's your tube that's causing an issue? Usually a high idle while coasting and sitting still is caused by the idle for control
I installed the 78mm bbk throttle body and tuner at the same time. I guess it could be the throttle body, how would I go about checking?
Old 12-07-2013, 03:30 PM   #4
I would clean your IAC first. What generally causes the high idle issue is either your idle screw is not set properly or the IAC is allowing too much air in
Old 12-07-2013, 03:32 PM   #5
TheWitness's Avatar
May give that a try, like I said it's only idling high after I give it gas. Whenever I come to a complete stop it settles back down to about 900.
Old 12-07-2013, 04:08 PM   #6
MidnightBlueGT's Avatar
Yeah try cleaning it. I have both those mods and cleaned mine while installing and runs good.
Old 12-07-2013, 04:24 PM   #7
xhgwx's Avatar
I've read countless reviews on bbk tbs
And they seem to be a hit and miss when coming to idle issues.
Do the easiest things first.
Return to stock tune see if it fixes.
If not take off the IAC and clean it
If not take off ur air induction tube and look into the TB and see how open it is, it could be the set screw.
xhgwx is offline   Reply With Quote
Old 12-07-2013, 04:26 PM   #8
Did you make sure it opened freely?
Old 12-07-2013, 05:27 PM   #9
TheWitness's Avatar
I'll just double check everything with the throttle body first, make sure everything is put back the right way.
Old 12-07-2013, 07:25 PM   #10
My BBK TB on my 95 was fine. Buddie's BBK TB on his 04 was garbage. They are VERY hit or miss. First thing you need to do is put the stock TB back on to rule that out. My money is on the TB being the culprit.
If it is the TB return it and get a Dragon or Accufab.
Old 12-07-2013, 09:33 PM   #11
Slow4V's Avatar
Don't forget to clean your mass airflow sensor too
Old 12-13-2013, 01:14 PM   #12
Speed_Mister's Avatar
Region: Arkansas
Could be the tb position sensor
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
01:04 AM
