Brakes stuck - Mustang Evolution
Old 12-08-2013, 06:48 PM   #1
Kstangs2002's Avatar
Brakes stuck
Just recently i notice when im driving and shift to nuetral seems to slow down as if its braking and i can hear it squealing on the front i checked all brakes and the front driver side rotor was super hot anyone know why or do i need a new caliper
Kstangs2002 is offline   Reply With Quote
Old 12-08-2013, 06:50 PM   #2
1996mustang's Avatar
Check the caliper slide pins first before assuming a sticking caliper. The slide pins if not lubricated well will cause the caliper to not return and cause the effect of a stuck caliper
Old 12-09-2013, 07:41 PM   #3
escottcarp's Avatar
I had the same problem about a month ago. My problem was a stuck slide pin. Easy fix.
If the pin is rusty, just sand it lightly and put brake grease on it. Check the rubber boot and replace it if it failed.
escottcarp is offline   Reply With Quote
Old 12-09-2013, 08:26 PM   #4
Sounds good will do that took it to the shop the guy just said go ahead and get a set of front calipers and it should fix the problem
His like $200 and ill do the labor
I said youlls hungry lol
I just need to find the time to do it myself ill park it till then
Old 12-09-2013, 08:31 PM   #5
Fender868's Avatar
Originally Posted by Kstangs2002 View Post
Sounds good will do that took it to the shop the guy just said go ahead and get a set of front calipers and it should fix the problem His like $200 and ill do the labor I said youlls hungry lol I just need to find the time to do it myself ill park it till then
I had that happen to me earlier this (on my 99 gt before I sold it of course). Was very cheap. Cost me 149$ for parts and took about 1 hour to do. I had a really rusted bolt that was pain in the ***, but it is really straight forward. Check online; there are some great write ups. I'd replace both front calipers if you can fork the money, but if not just make sure your pads don't need replacing before you take it apart. Otherwise, it might be worth it to get some fresh pads. Re install everything and do a quick brake bleeding .
Fender868 is offline   Reply With Quote
Old 12-13-2013, 06:43 PM   #6
Thanks for the advise went ahead and relubricated the slider pins and it worked
Old 12-13-2013, 08:54 PM   #7
escottcarp's Avatar
Great. Another easy fix.
04:55 AM
