Weird idle - Mustang Evolution
Old 12-08-2013, 07:15 PM   #1
96smoke's Avatar
Weird idle
Started noticing my idle gets weird whenever I have the heat/defrost on
If you start the car it idles just fine, though sometimes even without it on it'll act funny and go from about 600 - normal idle speed and keep dropping back and forth until I drive it
When you turn the heat on it'll drop and almost cut off but then jumps back up to normal idle speed and does fine after that
Something to do with IAC maybe?
96smoke is offline   Reply With Quote
Old 12-08-2013, 08:02 PM   #2
98GTCONV's Avatar
Get a custom tune
98GTCONV is offline   Reply With Quote
Old 12-08-2013, 09:03 PM   #3
JetLife 01GT's Avatar
Could be iac. iac is super easy to rule out by cleaning it. It takes 10 min with 5 of those min being the drying time after you clean it lol
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 12-08-2013, 09:14 PM   #4
04sonicbgt's Avatar
+1 I'll be cleaning mine tommorow lol
Sonic blue 04 GT~~bolt ons- headers, steeda tri ax, hi tech stage 2 cams coming this winter.
04sonicbgt is offline   Reply With Quote
Old 12-08-2013, 10:15 PM   #5
Yep. Sounds like the IAC. They are usually worn out by the time that they are dirty enough that they need to be cleaned.
Old 12-09-2013, 06:05 AM   #6
96smoke's Avatar
Alright I'll be starting there then
What do you guys use to clean it with
Old 12-09-2013, 10:11 AM   #7
A hundred dollar bill.
Or carb cleaner if you don't want to replace it.
05:16 PM
