1998 Mustang GT - Not starting. - Mustang Evolution
Old 12-08-2013, 10:46 PM   #1
I bought the car a month ago and it's been sitting in the driveway due to not having tags for it yet.
I tried to start it the other day and it does nothing but crank. Video below:
Things I have tried:
  • Having someone hit the tank while turning the key to try and start the fuel pump.
  • Changing the battery
  • Pulled all of the 40a fuses out, scrubbed the connects with sandpaper to clean them.
After cleaning the fuses, it will start to sputter like it's about to fire up when I turn the key.
If anyone else has a similar issue, all help is greatly appreciated
Molly is offline   Reply With Quote
Old 12-14-2013, 05:22 PM   #2
Vmcgrath's Avatar
Maybe try changing your fuel filter if you haven't already and check if you fuel pump is coming on when you turn the key over sometimes when a cars sits for a while your filter could get trash in it making it not fire up or your pump might went out
Vmcgrath is offline   Reply With Quote
1998 mustang
01:16 AM
