Nitrous vs 2v - Mustang Evolution
Old 12-11-2013, 04:34 AM   #1
Speed_Mister's Avatar
Region: Arkansas
Nitrous vs 2v
So as y'all know I'm spraying my 2v I've got cold air intake, Tb/p, spacer, under drive pulley's, tune, off road x-pipe, slp loudmouths I have stock internal stock rods and pistons, I'm getting colder plugs but don't know which ones, getting 24 pound injectors and hopefully a 310 LPH fuel pump soon. My question is what makes nitrous so dangerous i know I can blow my intake manifold but how could I avoid that from happening and from damaging my internals.? 25 shot 50 shot? I was think 75 but ik I don't wanna go more than that I'm just looking for a little more power
2004 Mustang GT 5 Speed
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 12-11-2013, 11:55 AM   #2
Slow4V's Avatar
You can run 75 shot all day long
100 is max for stock short block
Just get the colder plugs / good fuel system / good tune to go along with your kit
Old 12-11-2013, 11:57 AM   #3
Region: Arkansas
How do you prevent nitrous backfiring?
Full Bolt Ons
370rwhp 470rwtq
Old 12-11-2013, 12:02 PM   #4
Slow4V's Avatar
By purging the system properly before using
Forgot you need a purge kit too
Old 12-11-2013, 12:26 PM   #5
You prevent nitrous from backfiring by using a good kit, having a good tune and not being an idiot.
Old 12-11-2013, 02:11 PM   #6
Region: Arkansas
Ok I got the purge kit
Full Bolt Ons
370rwhp 470rwtq
Old 12-11-2013, 11:25 PM   #7
Set up and tuned right you will be able to handle a 125-150 shot. The tune is very key to nitrous.
Old 12-12-2013, 03:52 AM   #8
tommy d's Avatar
I run a 125 shoot on a 153000 mile stock bottom end for about 2 years now with the nitrous express plate kit . you want to get a window switch it helps ! Spraying the motor under 3k really hurts the bottom end , an a good dyno tune you will be good
tommy d is offline   Reply With Quote
Old 12-12-2013, 04:56 PM   #9
Slow4V's Avatar
If you do a nitrous shot at the plenum it hits harder .. Without putting bigger jets.
So I was told
Old 12-12-2013, 06:36 PM   #10
Best setup you can do is a fogger system. I don't like nitrous myself, never did. I want that power on tap all the time or not at all. For a dedicated drag car fine, not for a street car or weekend warrior. Just MO though.
Old 12-12-2013, 09:21 PM   #11
Region: Arkansas
That is exactly how I always felt but recently I've given in.
Full Bolt Ons
370rwhp 470rwtq
Old 12-12-2013, 10:27 PM   #12
Slow4V's Avatar
Let's face it nitrous is the easy way out for gains lol, I think if you ONLY use nitrous when you really need it.. It won't be bad
Lol when you hit 3rd gear and he's starting to walk you.. Hit that button haha
Old 12-12-2013, 11:52 PM   #13
Except Nitrous is designed to spray at certain rpms at WOT, that Fast and furious nitrous button is more show than reality.
Old 12-13-2013, 04:53 AM   #14
2002VertGT's Avatar
if we are going to refer to movies here I want the gone in 60 sec "go baby go" button..
4.10 Gear/RPM thread
Old 12-13-2013, 06:17 AM   #15
2300turboford's Avatar
You can put it on a button instead of a throttle switch but it has to be pushed down the while time
---------- Post added at 08:17 AM ---------- Previous post was at 08:17 AM ----------
Whole *
Old 12-13-2013, 12:43 PM   #16
Whole *
Yea but who really does that? Lol
Old 12-13-2013, 01:07 PM   #17
Most setups I see on drag cars are just tied to the throttle. When activated it sprays at WOT.
Old 12-13-2013, 01:09 PM   #18
Region: Arkansas
Do I need a n2o filter in my set up?
Full Bolt Ons
370rwhp 470rwtq
Old 12-13-2013, 01:59 PM   #19
Slow4V's Avatar
You can have the WOT switch , but you can have a on / off switch for daily driving , and for racing.
Old 12-13-2013, 02:54 PM   #20
Generally with the wot switch you just feather it coming out of the hole in 1st, floor it in 2nd and keep on flooring it/powershifting till you let off. That activates the N2O after you get higher up in the RPM range and also you don't have to think about it. With the auto you just come off the brake/footbrake and go right to WOT.
Old 12-13-2013, 03:19 PM   #21
tommy d's Avatar
A window switch allows you to control what rpm you want to spray at like mine is set up to hit at 3k and stops at 5700 just in case you miss a gear .
Wot switch is also smart because you don't want to spray nitrous at 3/4 throttle by mistake you're engine will not last long
03:49 AM
