Spark Plugs - Mustang Evolution
Old 12-11-2013, 07:01 PM   #1
robin_gt's Avatar
Spark Plugs
Hey Folks,
Tomorrow i´m going to change the spark plugs on my 02 gt and i just wanted to ask which brand/kind of spark plugs you guys would suggest
robin_gt is offline   Reply With Quote
Old 12-11-2013, 07:45 PM   #2
If your still pretty much stock, then OEM Motorcraft are fine and not to expensive.
Old 12-11-2013, 08:44 PM   #3
Slow4V's Avatar
Originally Posted by robin_gt View Post
Hey Folks, Tomorrow i´m going to change the spark plugs on my 02 gt and i just wanted to ask which brand/kind of spark plugs you guys would suggest
Ngk TR-555
Old 12-11-2013, 10:14 PM   #4
Kstangs2002's Avatar
NGK
Kstangs2002 is offline   Reply With Quote
Old 12-11-2013, 10:14 PM   #5
Put them in work good
Old 12-11-2013, 11:23 PM   #6
I will be doing mine as well tomorrow. I've seen different opinions on torque specs online. Anyone care to give their knowledge on this? First time changing plugs on the Stang.
Old 12-11-2013, 11:27 PM   #7
Slow4V's Avatar
Check stickies
Old 12-11-2013, 11:59 PM   #8
Just like Slows stickie.
Pay CLOSE attention while removing the plugs. Look for any that are hard to remove and generally don't back out smoothly. Those cylinders are the ones that you need to be VERY careful when reinstalling the plugs.
It's also a good idea to use some dielectric grease on the inside of the coil boots before you reinstall the coils.
It should all go smoothly...
Oh, and the torque spec?
Not too f'n tight!
Old 12-12-2013, 12:22 AM   #9
Originally Posted by Slow4V View Post
Check stickies
Cool, wasn't sure if it was there or not.
Old 12-12-2013, 07:58 AM   #10
robin_gt's Avatar
What should i gap them to?
Old 12-12-2013, 10:29 AM   #11
.054" I believe
Old 12-12-2013, 11:31 AM   #12
.054" I believe
I just noticed... YOU TOO!
So is it just the four of you or are there more?
Old 12-12-2013, 12:29 PM   #13
Torque spec is 12 ft lbs or 144 (set to 145) INCH lbs. Do NOT overtighten or you WILL blow out a thread. You can get a $20 torque wrench from Harbor Freight that is 1/4" drive and does up to 200 inch lbs.
Old 12-12-2013, 04:54 PM   #14
Slow4V's Avatar
Gap and TQ lb I put in my sticky..
It's 0.54 ( factory ) I know you gap more if you have more hp, but I don't think bolt ons will get you there.. More for power adders..
And 12lb to put them in,
Please do not forget to put anti-seize on the threads .. And be careful taking them off..
Old 12-13-2013, 07:25 PM   #15
There were 5 of us added
04:25 PM
