Need a new tensioner pulley? - Mustang Evolution
Old 12-14-2013, 01:46 PM   #1
2300turboford's Avatar
My cars been squeaking on an off for about a month it is a brand new belt so is it the tentioner pulley ? Every time it squeaks the pulley moves
Old 12-14-2013, 05:57 PM   #2
Bump.... Anyone?
Old 12-14-2013, 05:59 PM   #3
Count Dragula's Avatar
Very possible. Can you identify exactly where the squeak is?
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 12-14-2013, 06:03 PM   #4
Definitely the engine bay
---------- Post added at 08:02 PM ---------- Previous post was at 08:01 PM ----------
I'm wondering if it might be the through out bearings
---------- Post added at 08:03 PM ---------- Previous post was at 08:02 PM ----------
Throw *
Old 12-14-2013, 06:04 PM   #5
Can you not narrow down the location more? Throw out bearing would be towards the back and the pulley is the front lol kinda a wide range of possibilities there
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 12-14-2013, 06:09 PM   #6
I'm gonna try tomorrow I'm working tonight and its periodically so I'll try to catch it tomorrow
Old 12-14-2013, 07:31 PM   #7
96smoke's Avatar
Take your belt off and spin all the pulleys by hand
If one sounds like it has sand in it or is lose, then thats your issue
I just recently had to replace my tensioner pulley and I did that method first after installing a new belt, and it narrowed it down easily
96smoke is offline   Reply With Quote
Old 12-15-2013, 01:56 PM   #8
96NYCGT's Avatar
Send a message via AIM to 96NYCGT
I had a similar problem like that but it was My idling pulley
96NYCGT is offline   Reply With Quote
Old 12-15-2013, 02:33 PM   #9
BrandonMcCoy's Avatar
It may be the start of your timing chain wearing out. I did the EXACT same thing a couple of weeks ago. It continually got worse. I replaced all the pulleys and found out that it was the timing chain in the front of the motor and it was slapping the timing chain guide because it had gotten so loose.
This may not be your problem, but I went through the exact same thing about a month ago.
BrandonMcCoy is offline   Reply With Quote
Old 12-15-2013, 04:16 PM   #10
My TO bearing squeaks but it only does it when the engine is cold. It stops after being driven a bit.
If it's your TO bearing, it should stop squeaking as soon as you depress the clutch pedal.
Funny that you mention the tensioner pulley wobbling every time that you hear a squeak. My truck is doing the same thing. Both the belt and the pulley are brand new. As a matter of fact, they have been replaced TWICE! This has been an ongoing problem. I have it isolated to one side of the engine.
It's frustrating!
I still suspect that damn tensioner pulley...
Let us know what you find.
Old 01-03-2014, 07:08 AM   #11
96NYCGT's Avatar
The sound of my idling pulley
http://youtu.be/fybNMb8m7ik
Old 01-04-2014, 06:18 PM   #12
Had the same issue in the summer. Changed the belt first which made it a bit better but not perfect. Changed the tensioner and problem solved. There cheap on ebay and only take a few minutes to swap out
mr.deeds is offline   Reply With Quote
Old 01-04-2014, 09:37 PM   #13
fomoco4life's Avatar
Mines idler pulley, can narrow it down shootin wd on each pulley during squeek. Mine only squeeks while colf
---------- Post added at 08:37 PM ---------- Previous post was at 08:36 PM ----------
Mines idler pulley...can narrow it down shootin wd on each pulley during squeek. Mine only squeeks when cold
Old 02-22-2014, 10:19 PM   #14
Squeak Squeak Squeak Squeak
I finally figured out what was causing my squeak.
Did you ever get yours to stop?
02:07 AM
