Rear axle replacement - Mustang Evolution
Old 12-15-2013, 11:25 AM   #1
BigB227's Avatar
Been awhile since I've been on, Just finished the Fire Academy. But anyways i suspect that I have a bent axle on my passenger side. I hit a curb quite some time ago from being run off the road by a drunk. My rear passenger wheel had a slight wobble to it and I have a squeak from the rear when applying the brakes. I replaced the rear calipers and pads so I know it's down to the axles. So my question is How hard is it to replace axles on a 2003 Mustang Gt? I've pretty much decided on putting in 31 spline axles with a 31 spline limited slip differential. Is this something that can be tackled by someone in their backyard or does it require many specialty tools and expertise????
BigB227 is offline   Reply With Quote
Old 12-15-2013, 11:28 AM   #2
Slow4V's Avatar
Don't do it yourself. Take it to a shop
Old 12-15-2013, 11:41 AM   #3
BigB227's Avatar
Alright man thanks, didn't think it was something I could tackle
Old 12-15-2013, 12:28 PM   #4
The actual parts aren't hard to put in place. The hard part is getting all of the tolerances correct.
If you're going to tear it down go ahead and do bearings.
Old 12-15-2013, 12:29 PM   #5
BigB227's Avatar
The actual parts aren't hard to put in place. The hard part is getting all of the tolerances correct. If you're going to tear it down go ahead and do bearings.
Well I had all the bearing and deals replaced when I had 3.73s put in and then the accident happened later so all the bearing and seals are less then a year old
Old 12-15-2013, 05:08 PM   #6
surfinglbi23's Avatar
I've done several axle swaps on jeeps though it's not exactly the same, I've swapped in 8.8 rears and it's very easy. If you are pretty handy I'd take a crack at it. Lots of good write ups online.
surfinglbi23 is offline   Reply With Quote
Old 12-15-2013, 05:26 PM   #7
Slow4V's Avatar
Main issue is setting the backlash on the gears.
Old 12-15-2013, 05:35 PM   #8
Roguestang's Avatar
+1
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 12-15-2013, 09:32 PM   #9
+2 the gears are the only hard part for the average mechanic with a good set of sockets/wrenches. Everything else comes right out and goes right back in pretty much.
Old 12-15-2013, 09:58 PM   #10
BigB227's Avatar
Yeah the gears are the only thing making me feel like I should definitely take it to a good mechanic
Old 12-15-2013, 10:48 PM   #11
Slow4V's Avatar
I took mine to a " good " mechanic and he couldn't set them right .. Took them atleast 6 times , until they took it to a real shop ,
Old 12-15-2013, 11:32 PM   #12
BigB227's Avatar
Well I know a small shop that's run by a guy who has been working on rear ends for 15+ years, he did my 3.73 swap like a year back and was perfect from day one, so I know he is good from experience.
Old 12-16-2013, 07:03 AM   #13
I had a place like that do the gears in my 95 back in the day. Great price, 2 hours while I waited and drove off like it was stock.
09:50 AM
