Santas being good - Mustang Evolution
Old 12-15-2013, 12:03 PM   #1
Peterzinyou's Avatar
Santas being good
So "SANTA" has gotten me SVE rear UCA & LCA from Latemodel, Powerstop drilled/slotted rotors and ceramics from AM. Next will be SVE front and rear calipers. My question is any other brake/suspension components I should consider? Thanks guys.
Borla S-Type stingers, BAMA SCT tuner, K & N Typhoon CAI, Classic Design Concepts light bar, MACH 1 chin spoiler, MACH 1000 w JVC Kvw 500 HU, plastidipped hood scoop, wing & Premium GT rims, painted calipers, 3.73 gears, black Bullitt fuel door, MMD hood struts, sub-frame connectors, SVE uca & lca, Power Stop drilled/slotted rotors
Peterzinyou is offline   Reply With Quote
Old 12-15-2013, 12:30 PM   #2
Slow4V's Avatar
Well what's your current mod list already done
Old 12-15-2013, 12:33 PM   #3
Mile high JDF's Avatar
+1^ maybe look in to some subframe connectors next?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-15-2013, 12:55 PM   #4
Got subframes. K and N CAI, BORLA exhaust 3.73 ans Bama tune.
Old 12-15-2013, 12:59 PM   #5
Definitely do lowering springs and shocks/struts
Old 12-15-2013, 01:03 PM   #6
What else will need to be done with that? Do I need the camber? plates or bump steer? Want to make sure I get everything I need. Also, I am,mechanically retarded, I will have a shop do this.
Old 12-15-2013, 01:08 PM   #7
Depends on how low you go. C/C pates are always a good idea, you won't really need Steeda X2 balljoints or a bumpsteer kit until you lower it past 1.6" or so
Old 12-15-2013, 01:09 PM   #8
Slow4V's Avatar
You can do
Struts / shocks
Springs
Steeda lower ball joints if you want lower
Caster / camber plates ( not really needed unless your into racing )
Old 12-15-2013, 01:11 PM   #9
So an inch, inch and a half drop, I will need only springs and shocks/struts? Ty guys, appreciate it.
Old 12-15-2013, 01:38 PM   #10
Slow4V's Avatar
2 inches is a drop
Anything else isn't noticeable
Old 12-15-2013, 01:44 PM   #11
PonyBoyV6's Avatar
I'd really pick up a set of CC plates if you're going 1.5 or lower. Even a cheap set, just to get the car back in spec. Your tires will thank you.
PonyBoyV6 is offline   Reply With Quote
Old 12-15-2013, 01:45 PM   #12
I disagree with 1.5 not being noticeable. 0.5 isn't noticeable but 1.5 is
Old 12-15-2013, 01:45 PM   #13
96NYCGT's Avatar
Send a message via AIM to 96NYCGT
I just install the SVE rear control arms and my 96 GT feels way much better
96NYCGT is offline   Reply With Quote
Old 12-15-2013, 01:53 PM   #14
Awesome ty
---------- Post added at 03:53 PM ---------- Previous post was at 03:52 PM ----------
So camber plates regardless. Ty
Old 12-15-2013, 05:11 PM   #15
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
Santas being good
Agent 47 makes some brake ducting that aid in brake cooling if you track or autocross your car.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 12-15-2013, 05:19 PM   #16
Want to hit the drag (test and tune) in 14, no plans for autocross
Old 12-15-2013, 06:14 PM   #17
Slow4V's Avatar
Get maximum motorsports plates if you decide on any
Don't get the SR ones
Old 12-15-2013, 08:35 PM   #18
Don't get SR anything.
Old 12-15-2013, 08:39 PM   #19
BigB227's Avatar
SR is a bad company?? I was looking at their coil over kit mostly because it's a lot cheaper then the Eibach system
BigB227 is offline   Reply With Quote
Old 12-15-2013, 09:20 PM   #20
If you want cheap coilovers at least get UPR, they usually run specials this time of year. SR=cheap chinamen made crap. Seems you have to wade through a flood of it these days to get to anything half decent.
Old 12-15-2013, 10:00 PM   #21
BigB227's Avatar
Hmmm oh ok yeah that makes sense, I never did research the company so I didn't know but thank you for the input, do you have any links or sites that sell a good coil over kit for a 2003 mustang gt?
Old 12-15-2013, 10:36 PM   #22
Slow4V's Avatar
Yeah seriously, don't go SR, you'll regret it later trust me.
Old 12-15-2013, 10:40 PM   #23
How much money do you want to spend. If you want a quality non drag racing setup I would look into KW, Briggs Racing, or Maximum Motorsports
Old 12-15-2013, 11:33 PM   #24
BigB227's Avatar
I'm not looking to break the bank but I do want to make sure what I buy is good and I won't regret later down the road
Old 12-16-2013, 07:02 AM   #25
For a straight line setup the upr kit is fine. If you want handling and the best one as far as construction the max motorsports setup. I'd swap the k out too and there are full k member/coil over kits from both places. Upr is way more budget friendly but like I said is pretty much only good for going fast straight. It is the lightest setup you can get BTW.
Old 12-16-2013, 07:52 AM   #26
BigB227's Avatar
Yeah I'm looking for a good handling all around so I'm going to look at Maximum Motorsports
Old 12-16-2013, 10:28 AM   #27
$1700 of the K/coilover full kit from MM. I'd roll with the forward offset A arms as well, puts the wheel dead center in the front wheel well and longer wheelbase=better. If you look at yours right now, the wheel will be aft of center. I actually hate that about the stock setup and it sets off my OCD lol. Problem is its a good $1k more expensive than the UPR K/coilover setup.
There are other brands too, research, research, research but for your best "not going to break the bank" handling setup you can't beat MM.
Old 12-16-2013, 03:01 PM   #28
BigB227's Avatar
$1700 of the K/coilover full kit from MM. I'd roll with the forward offset A arms as well, puts the wheel dead center in the front wheel well and longer wheelbase=better. If you look at yours right now, the wheel will be aft of center. I actually hate that about the stock setup and it sets off my OCD lol. Problem is its a good $1k more expensive than the UPR K/coilover setup. There are other brands too, research, research, research but for your best "not going to break the bank" handling setup you can't beat MM.
Great info thank you Scotty, I'll definitely look into the MM kit and yeah I've always thought about going with an aftermarket K member
02:01 AM
