Hanging idle issue - Mustang Evolution
Old 12-20-2013, 02:12 AM   #1
philbo9's Avatar
Hanging idle issue
I have a 2004 mach 1 and about 4 months ago i started noticing that my rpm's would stick when downshifting and if i engage the clutch while moving to shift up the rpm's will shoot up to 3000 and wont come back down till i put it in gear and start moving or turn the engine off. Also, when at a stop i rev the engine and the rpm,s will just hang at whatever i reved it to. I figured it was the tps or iac valve. I replaced the tps and cleaned the iac valve as well as a new gasket and also cleaned the throttle body. It is still having this issue. I have read lots of other forums and cannot seem to get a solid solution for this problem. Also, this does not occur every time i drive it but is very frequent and seems to be worse when the a/c is on. Any input on this problem would be greatly appreciated.
philbo9 is offline   Reply With Quote
Old 12-20-2013, 06:33 AM   #2
http://www.mach1registry.org/forums/...ad.php?t=18330
If you have a Mach, I highly recommend registering for that site as well, book mark it, a lot of good info in there just for mach 1's
Old 12-20-2013, 09:25 AM   #3
weschris's Avatar
Try putting a 1/4 inch socket in the hose after the iac and before the Tb , mine used to hang up until I limited the airflow , but I have a Bulitt intake manifold and 2v TFS heads and cams
---------- Post added at 04:25 PM ---------- Previous post was at 04:23 PM ----------
Excuse me before the air inlet
02 GT,Ford racing C springs,Tokico rear shocks,Mpr full length subframe connectors,Kyb adjustable front struts,hardened steel axles,3.73 gears,Bbk uppers,Granitelli adjustable lowers, Mach 1 seats,Steeda Tri ax shifter,Exedy stage 2 clutch,Firdanza aluminum flywheel,Bbk adjustable clutch quadrant,Bbk shorty headers ,Mpr catted x pipe,Pypes Violator catback,Jlt cai,Bulitt intake manifold,Venom 24 lb injectors,Ngk iridium plugs,TFS twisted wedge heads and cams,stock short block ,custom dyno tune on a Mustang dyno.
weschris is offline   Reply With Quote
Old 12-20-2013, 09:28 AM   #4
weschris's Avatar
Name:	ImageUploadedByMustang Evolution1387556892.595843.jpg
Old 12-20-2013, 09:32 AM   #5
weschris's Avatar
Ok if you zoom on the photo , look at the tube attached to the iac ,I put a 1/4 inch socket inside of the hose just before the iac to limit the airflow , it worked , mine used to idle really high and then go down kinda, it couldn't stand it
06:20 AM
