Rattle,shaking,vibrate - Mustang Evolution
Old 12-22-2013, 02:40 AM   #1
Kstangs2002's Avatar
I notice my car just started rattleling its more noticible on 5th gear like a vibrating rattle could it be my drive shaft
Kstangs2002 is offline   Reply With Quote
Old 12-22-2013, 08:28 AM   #2
ward.r's Avatar
Is there any noise that changes pitch as you hit higher gears??
ward.r is offline   Reply With Quote
Old 12-22-2013, 10:56 AM   #3
No i dont think its notisable till i go on to 5th gear that when it sort of vibrates for about a second and 2-3 seconds later vibrates again and so on but only on 5th gear
Old 12-22-2013, 11:01 AM   #4
ward.r's Avatar
Thats hard to say if it had a constant vibration with a noise that changes pitch with higher gears it would be your rearend.
Old 12-22-2013, 11:03 AM   #5
Check your tires for wear, damage, or out of balance.
Old 12-22-2013, 11:05 AM   #6
I just got new axels put in and trans rebuilt and new clutch not to long ago my friend says to check out make sure there not something loose like the u joint
Old 12-22-2013, 11:10 AM   #7
ward.r's Avatar
I was kinda thinkin maybe a u joint but i always felt a shutter when that happen. But thats a good place to start. Make sure there no play in the drive shaft
Old 12-22-2013, 11:14 AM   #8
Ok thanks i will go by the shop after work see what they say
---------- Post added at 12:14 PM ---------- Previous post was at 12:13 PM ----------
Oh i do need rear tires so i will replace them as well today before i travel back home
» Members Mustangs
RUTH
shoes64
Rosco
Rosco
Add your Mustang
08:38 AM
