2003 GT reluctant starting - Mustang Evolution
Old 12-22-2013, 09:44 AM   #1
Region: West Virgina
My 2003 GT is reluctant to start unless I turn the ignition on, wait about 20-30 seconds and then try to start it. If I only wait about 10 seconds it cranks with good speed but does not start. Is this typical of the car when new or should I worry about the computer starting to go bad. The car has 107K.
WEBSTAR62 is offline   Reply With Quote
Old 12-22-2013, 10:27 AM   #2
Mile high JDF's Avatar
Have you tried cycling the key on and off a couple times before starting? It's probably your fuel pump on its way out
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-22-2013, 10:57 AM   #3
Yep. Sounds like a fuel delivery problem. Put a new fuel filter in and see if that helps. If it doesn't, do a fuel pressure test to determine the condition of the fuel pump.
Old 12-22-2013, 10:24 PM   #4
mike_jay5.0's Avatar
Common problem. The fuel pump has a check valve that holds pressure. The check valves goes bad and allows the fuel to float back to the tank. New fuel pump will fix the problem
mike_jay5.0 is offline   Reply With Quote
Old 12-23-2013, 04:54 PM   #5
BigB227's Avatar
Sounds like what my 03 Gt was doing and I had to replace the fuel pump. It's not that hard of a job just a bit time consuming, I'm 20 years old and was able to tackle this and replacing my intake manifold in the same day. I also cleaned out my fuel tank while I was at it so I didn't have to worry about the dirt and sediment in my new pump
BigB227 is offline   Reply With Quote
04:24 AM
