Car pulls to right when braking. - Mustang Evolution
Old 12-29-2013, 12:02 PM   #1
It has been going on for a while but has recently gotten worse. If I brake with my hands off the wheel I can see the wheel move. I have just put new calipers, pads, rotors, and new front brake hoses on and the problem is still there. Also have gotten new tires and a front end alignment recently. Let me know of any other ideas
Bparri1 is offline   Reply With Quote
Old 12-29-2013, 12:15 PM   #2
It's not me, it's you.
primer2tone's Avatar
Wow, that's gotta be irritating. Maybe a wheel bearing? Have you done any work to the rear brakes?
Old 12-29-2013, 12:30 PM   #3
I forgot to mention I did the bearings when I did the front brakes. Haven't done anything in the rear except for pads. My car has 165,000 miles on it.
Old 12-29-2013, 12:35 PM   #4
That is really odd! How bad does it pull? How does the pedal feel?
Old 12-29-2013, 12:42 PM   #5
The pedal feels great had plenty of braking power. It pulls enough to be annoying and have to correct it.
Old 12-29-2013, 12:45 PM   #6
Mfore33's Avatar
If you still have the original calipers on the back it could be a rusted guide pin. Mine had the rubber boot tear and water got in and rusted the guide pin on the right side. Caused the pads to wear uneven and brake pull
Old 12-29-2013, 01:05 PM   #7
The problem could be a rear caliper as said above. Or maybe the master cylinder? But I think one line supplies both front calipers and the other line supplies the rear but I'm not positive.
Old 12-29-2013, 01:24 PM   #8
Roguestang's Avatar
Did you bleed the brakes properly? When you replaced the front calipers there could be air in one of the lines, and the caliper is not gettin as strong a bite as the other side.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 12-29-2013, 05:18 PM   #9
I did bleed the brakes properly. This was happening before I touched the brakes. So I guess my next step it looking at the rear
Old 12-29-2013, 05:28 PM   #10
Roguestang's Avatar
Gotcha. Could be the stock hoses are expanding more on one side than another too. I'm just thinking online, aka outloud lol
Old 12-30-2013, 05:26 PM   #11
UltArc's Avatar
Have you personally checked tire pressure?
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline   Reply With Quote
Old 01-02-2014, 07:50 PM   #12
UltArc's Avatar
Did that fix it?
Old 01-03-2014, 11:38 AM   #13
Negative all tire pressure are same. Haven't got a chance to take a look at the rear brakes yet
Old 01-04-2014, 06:42 AM   #14
UltArc's Avatar
Ah, I was hoping that was it. Buddy had the same issue with a 2 month old Fusion. No one could figure it out. I went to borrow it, it pulled right real hard...checked the air pressure, and the front passenger was near 20 with the others ~45.
Dude never even said thanks.
Old 01-04-2014, 08:02 AM   #15
Roguestang's Avatar
That's when you let some of the air out of the opposite tire and tell him the other side is doing it now lol
11:09 PM
