No spark to coil..Need Help! - Mustang Evolution
Old 01-01-2014, 08:23 PM   #1
Mike93coupe's Avatar
Got a issue with my coupe.. It will crank sometimes and then it won't. When it does crank it will run 20 - 30 seconds and cut off.. I have change the TFI, distributor, coil, wires, and plugs. I need some help with this one. Thinking computer?
Mike93coupe is offline   Reply With Quote
Old 01-03-2014, 08:27 PM   #2
1996mustang's Avatar
How strong is the fuel pressure? Maybe your losing fuel pressure. Are you on timing correctly on the distributor? And when it does run does it cut off slowly till it dies or just straigh up 20 sec and blah dead as a door knob?
Old 01-05-2014, 05:20 AM   #3
Talking
Dude it goes dead as a door.. I replaced coil, wires, plugs, distributor, and TFI module. No luck. Then I took computer off a 91 lx and she fired right up. Put old computer back on and she was dead again. So I ordered new computer. At least now the ignition on car is new condition. Lol.. Thanks for your help!!
Old 01-06-2014, 02:20 PM   #4
Good to hear you found the problem.
09:28 AM
