NA power limit - Mustang Evolution
Old 01-02-2014, 07:40 PM   #1
Slow4V's Avatar
NA power limit
So I have a chance to buy some C heads for cheap so I was considering building a NA build..
Ported C heads
Custom grind camshafts
Lifters , rockers, springs upgraded
ARP bolts / studs
Ported short runner
Intake manifold spacer
Throttle body ( kind of a waste )
Crank pulley from Steeda
Electric water pump
JLT true cold air intake
90mm MAF
Longtube headers
Tubular K member
Tubular A arms
Steeda lower ball joints
90/10 struts
Opinions ?
Old 01-02-2014, 07:42 PM   #2
ColeJohnson's Avatar
What kind of power do you think you'll make?
2016 Comp Orange GT (current)
Old 01-02-2014, 07:54 PM   #3
Slow4V's Avatar
Idk ?
My buddy's Mach 1
Cams
Full exhaust
Ported short runner
Cold air intake
Intake spacer I believe
Lower control arms
Dyno tune
410s
Is running 12.1 @119
Old 01-02-2014, 09:00 PM   #4
Redsvtcobra's Avatar
I say do it! I have a cold air intake, exhaust, and 4.30s. And a dyno tune and my car ran a 12.7 on street tires. So with that set up I would say you could be down near 400-450 on all motor. A buddy if mine did all new internals (beefed up the motor) and he's almost 500 on all motor. It's pretty impressive
Redsvtcobra is offline   Reply With Quote
Old 01-03-2014, 08:17 AM   #5
You won't make enough power NA to worry about breaking the powdered metal rods in your Mach. With that said I'm not sure its worth the money to port the C heads with the displacement you are running right now and it will suck when a 2V with a S trim walks you for less money. I mean you already have the revised C heads on the car you have now.
Whatever happened to that cheap Eaton swap you were planning on? IMO that would be the way to go.
Old 01-03-2014, 09:44 AM   #6
Slow4V's Avatar
Lost my job and he sold it /:
Now I'm working again,
03:09 AM
