Need engine help - Mustang Evolution
Old 01-11-2014, 06:42 AM   #1
Anth0nyxGT00's Avatar
Need engine help
Used my dad's car for a day he left my door open and ever since the car takes longer to start then normal switched the battery out to an optima red top and still having the same problem Idk Wuts going on in guessing starter Idk tho opinions would be greatly appreciated
Sent from my HTCONE using Mustang Evolution mobile app
---------- Post added at 06:42 AM ---------- Previous post was at 06:40 AM ----------
Also i want to know ways to make the car breathe better besides taking off the cats I've changed the cai to a specter Idk if that would help I've cleaned the iac and the maf also have changed ignition coils
Anth0nyxGT00 is offline   Reply With Quote
Old 01-11-2014, 06:46 AM   #2
Slow4V's Avatar
The spectre will not making it breathe better, it will suck a lot more hot air in
If you want better airflow you need to buy a TB and plenum for starts
---------- Post added at 08:46 AM ---------- Previous post was at 08:44 AM ----------
Easy way to check is take your car to auto parts store so they can test your battery and alt for free
Old 01-11-2014, 06:47 AM   #3
So I'll switch back to the stock air box then
Old 01-11-2014, 06:50 AM   #4
Slow4V's Avatar
Stock is always best, spectre is cheapy metal and it will absorb more heat in engine bay, you'll probably lose hp as well,
I'd recommend the JLT next gen cold air intake, because it's not made of any metals , it's like plastic
Old 01-11-2014, 10:32 AM   #5
BadAssStang07's Avatar
I have the spectre cai, and I could tell a better difference than stock with a lil more power and better throttle response so please tell me how you know that it makes you lose hp.?
BadAssStang07 is offline   Reply With Quote
Old 01-11-2014, 11:02 AM   #6
BigB227's Avatar
Need engine help
He's not saying you WILL lose hp but the potential for heat soak over a period of time can heat the incoming air up to have a Potential for horsepower loss. It's like having an all metal intake manifold, while making a couple passes down the track will net some gains, having it on a daily driver or street car will cause heat soak causing a horsepower loss
BigB227 is offline   Reply With Quote
Old 01-11-2014, 11:08 AM   #7
Ok but mine is made out of aluminum and I didn't think that it trapped heat like a metal one would
Old 01-11-2014, 11:46 AM   #8
Mile high JDF's Avatar
The S197s will actually benefit from a CAI unlike the SN95s
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-11-2014, 12:15 PM   #9
Gonna invest in a airaid cai from AM
Old 01-11-2014, 12:29 PM   #10
Slow4V's Avatar
Only major gains from cold air intakes are the new 5.0
Old 01-11-2014, 02:18 PM   #11
So i should jus go back stock then
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
Useful Mustang Information - READ THIS FIRST! Trojan Horse 1979-1995 Mustang GT 24 11-19-2012 09:54 PM
Service Engine Soon Light???? wilson_j307 Pre-2005 V6 Mustang 2 03-03-2012 12:41 PM
Engine swap question!! Tominkc 1996-2004 Mustang GT 1 02-09-2012 12:15 AM
Engine seized! 2012 gt 5.0 8WOOD 2011-2014 Mustang GT 94 12-01-2011 12:39 AM
07:56 AM
