HOW TO : Rear Upper Control Arm - Mustang Evolution
Old 01-11-2014, 05:49 PM   #1
Slow4V's Avatar
I have some free time so I decided to make a how to for you guys who want to do your own work.
Things used : 18mm Ratch Wrench, 19mm Ratch Wrench, 2 stands, Floor jack, Tire Blocks
1. Block tires, so the car doesn't roll back and kill you.
Name:	ImageUploadedByMustang Evolution1389483552.874476.jpg
2. Jack up both sides evenly
And high enough for you to crawl under.
Name:	ImageUploadedByMustang Evolution1389483601.098355.jpg
3. Roll jack under pumpkin just barely to not lift it , but support it from not moving when you remove the upper arm.
Name:	ImageUploadedByMustang Evolution1389483665.926934.jpg
4. With your wrenches , hold the bolt with the 18mm and undo the nut with the 19 Click image for larger version
Name:	ImageUploadedByMustang Evolution1389483693.765622.jpg
5. Do the exact same with the upper bolt and nut located above the exhaust in a Tight space. ( have patience )
Name:	ImageUploadedByMustang Evolution1389483796.026454.jpg
6. Remove the upper arm ,Click image for larger version
Name:	ImageUploadedByMustang Evolution1389483858.765878.jpg
Name:	ImageUploadedByMustang Evolution1389483872.280114.jpg
7. Apply grease on the outside of the bushing on both sides, and the bushing on the pumpkin. ( diff )
Name:	ImageUploadedByMustang Evolution1389483918.992436.jpg
8. Install the bolt and nut on the top FIRST , 18mm for bolt and 19mm for nut.. I tighten them pretty good
Name:	ImageUploadedByMustang Evolution1389484023.924887.jpg
9. Once you look at the bottom hole, it's going to be off because the angle of the differential is off from the last position.
Don't be discouraged Click image for larger version
Name:	ImageUploadedByMustang Evolution1389484076.683562.jpg
10. Simply change the position of the jack to the back ( near driveshaft ) and jack it up until the hole is evenly matched with the new control arm.
Name:	ImageUploadedByMustang Evolution1389484130.265832.jpg
11. Install the new arm, and lower the car, and have a beer.
Old 01-11-2014, 06:10 PM   #2
Nice How-to!
Old 01-11-2014, 06:41 PM   #3
Slow4V's Avatar
Thanks stray, I chose to use hand tools because I know everyone can't afford air tools or hand held impacts.
Old 01-11-2014, 07:29 PM   #4
For anyone wondering. THIS is what a tech thread is. Great "How To" Slow4v!
Old 01-11-2014, 08:07 PM   #5
Slow4V's Avatar
Thanks soccer , I have MANY more coming, just need some time , and PARTS first haha
Old 01-11-2014, 08:39 PM   #6
White03GT's Avatar
+1
White03GT is offline   Reply With Quote
2.3 turbo build BigRed1781 2.3 Mustang 133 04-30-2016 11:46 AM
Useful Mustang Information - READ THIS FIRST! Trojan Horse 1979-1995 Mustang GT 24 11-19-2012 10:54 PM
Factory speed control or dealer speed control (cruise control) Otlaw80 1979-1995 Mustang GT 6 08-18-2011 08:42 PM
Rear control arms jhagan1980 1979-1995 Mustang GT 1 08-17-2011 08:24 PM
01:30 PM
