Suspension problem - Mustang Evolution
Old 01-17-2014, 04:37 PM   #1
JayStang718's Avatar
Suspension problem
So I've been having this problem whenever I turn the wheel I hear a creaking noise coming from up front. In the summer I change my rack which didn't fix it and then I change both ball joints which fixed it. So about 2 weeks ago the same noise came back. Today I change the outter tie rods and got an alignment and on my way home the noise came back. Any ideas??
JayStang718 is offline   Reply With Quote
Old 01-17-2014, 04:49 PM   #2
Suspension problem
Forgot to mention it also does it when I go over bumps and when I'm braking, then the car comes to a stop it'll do it
Old 01-17-2014, 04:51 PM   #3
Did you replace the steering rack bushings when you replaced the rack?
How old are the struts?
A commonly overlooked item is the strut bushings.
When you replaced the ball joints did you also replace the A-arm bushings?
Old 01-17-2014, 04:58 PM   #4
The only bushings that were replaced was the steering rack bushings which was done when the rack was changed.
Honestly I'm not sure how old the struts are I bought the car at 67k it has 82k now
Old 01-17-2014, 05:06 PM   #5
Well the struts and strut bushings could be a possibility. Also the A-arm bushings.
Soon you'll have a completely new front end...
Old 01-17-2014, 05:10 PM   #6
Lol yeah I will that's a good thing I guess I won't have to worry about anything for a while as far as the front end. I'm going to check the bushings in the morning thanks for your help!
Old 01-17-2014, 05:29 PM   #7
fomoco4life's Avatar
Did you grease new ball joints?? I'm having the same problem and sounds like it's coming from outer tie rod end. Don't want to change my rack if I don't have to. Already changed ball joints..( didn't get Steeda X2's..big mistake.. I will be getting them soon). I greased my brand new junkie boxstore ball joints 2day and squeek stopped.
Old 01-18-2014, 06:31 AM   #8
Slow4V's Avatar
Happened to me , I replaced so many things and I ended up taking it to a ford expert and he gave me a HUGE tip
He said our cars were notorious when they came out with the cradle bolt up front coming loose ,
So I tighten mine ( weren't very tight) and problem solved .. ( cradle is what holds engine )
Old 01-18-2014, 07:53 AM   #9
CliffyK a member here also has a tutorial on his site on how to replace the steering rack bolt sleeves which led the steering creak. There was a TSB for this and Ford made updated sleeves which were shorter. The creaking is from the sleeve being too long and running against the large washer when turning especially at slow speeds.
Old 01-18-2014, 11:15 AM   #10
Interesting info..will investigate..thanks
'97 Cobra Need Suspension Options robb15033 1996-2004 Mustang GT 0 02-03-2013 06:05 AM
Front end appearaance, or suspension mods? Can't decide OrganDonor 2011-2014 Mustang GT 14 12-28-2012 08:08 AM
what suspension parts to put power to ground?? mhobbs 1996-2004 Mustang GT 8 03-09-2012 04:29 AM
Suspension NeedSomeMods 1979-1995 Mustang GT 11 01-09-2012 03:11 PM
66 suspension gc19662007 Classic Mustangs 5 11-26-2011 08:38 AM
02:15 PM
