Wall going into 3rd gear - Mustang Evolution
Old 01-19-2014, 12:17 AM   #1
Ok so for anyone who doesn't know I have a 2001 Bullitt with the TR3650 transmission (5 speed).
When I am really on the gas going to redline and i'm going to shift from 2nd to 3rd a lot of the time it will literally feel like there is a wall there and i will have to wait a second or 2 before it will finally let me go into 3rd. It only happens when i am going hard from 2nd to 3rd.
I have an MGW shifter also.
Does anyone know what the issue might be, and how I can fix this?
Old 01-19-2014, 12:21 AM   #2
03Graymach's Avatar
Do you have the stock shifter
03Graymach is offline   Reply With Quote
Old 01-19-2014, 12:24 AM   #3
I have an MGW, i'll update the first post with that info for everyone else.
Old 01-19-2014, 12:51 AM   #4
Try draining the transmission and refilling it with 3.25 quarts of Mobil 1. (Cliffy's fav!)
There might be some windage going on from too much trans fluid.
Another reminder that I, also, need to do mine...
Old 01-19-2014, 12:53 AM   #5
[QU OTE=straybullitt;1926893]Try draining the transmission and refilling it with 3.25 quarts of Mobil 1. (Cliffy's fav!)
Another reminder that I, also, need to do mine...[/QUOTE]
Ok I've been wanting to change the fluid. I've never changed tranny fluid, how would I go about emptying it? I know how to fill it.
Old 01-19-2014, 12:55 AM   #6
There's a drain plug on the bottom of the transmission.
Old 01-19-2014, 12:59 AM   #7
03Graymach's Avatar
Yeah I would deff change tranny fluid with Mobil 1 or royal purple and check the bolt on the back of your shifter and make sure it's adjusted right had mine push to far forwarded and it did the same thing to me but was 5th gear
Old 01-19-2014, 01:05 AM   #8
Ok I'll see when I get a chance. It's hard to do work on the car when I live on campus with only a small tool kit.
Old 01-19-2014, 01:06 AM   #9
The 3650 uses Automatic tranny fluid right?
Old 01-19-2014, 01:07 AM   #10
03Graymach's Avatar
Know what you mean been there and I had to change my tranny fluid then too so know how much of a b*tch it can be
---------- Post added at 02:07 AM ---------- Previous post was at 02:06 AM ----------
The 3650 uses ATF right?
Yes dextron 4 I believe not 100% on that but pretty sure
Old 01-19-2014, 01:33 AM   #11
So i started looking at different fluids from different forums people recommend. It seems like almost any place i search a majority of people are saying GM Syncromesh.....
Old 01-19-2014, 08:04 AM   #12
WJBertrand's Avatar
I vote for red line MTL.
-Jeff-
STOC 025
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 01-19-2014, 12:12 PM   #13
Cliffy says Mobil 1
The manual says Mercon, I believe...
Old 01-19-2014, 01:10 PM   #14
Getn off's Avatar
Not sure on ur shifter, but mgw says there is an adjustment on mine (14) for locking out third. Might check that first.
Troy
Getn off is offline   Reply With Quote
Old 01-22-2014, 12:24 PM   #15
JetLife 01GT's Avatar
Mercon V. I used valvoline bcuz it was the only name brand mercon V I could find at 3 diff stores
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
Crunchy 3rd gear Fballman9 1979-1995 Mustang GT 8 06-02-2013 08:17 PM
Gear Options with MT82, Boss IM and Tall Tires Napoleon85 2011-2014 Mustang GT 2 04-22-2012 06:44 PM
3rd gear stumble AgentOrange 1996-2004 Mustang GT 0 04-21-2012 09:57 AM
3rd gear power?..... Gibby 2011-2014 Mustang GT 10 01-22-2012 10:51 PM
11:03 PM
