Need help adding Transmission fluid. - Mustang Evolution
Old 01-24-2014, 10:58 AM   #1
shawn.velez36's Avatar
I have a 03 manual. I have been all over the internet trying to find the best solution to figure out how best to change the transmission fluid. Does anyone have a GOOD solution to do this or have any experience with this. Help me please!!
shawn.velez36 is offline   Reply With Quote
Old 01-24-2014, 11:02 AM   #2
GHO5T5NIPER's Avatar
There is a bolt on the bottom side of your tranny that you'll have to take out to drain the oil. The way I've done it is by taking apart the shifter from inside the car and pouring it in through there. Easier than pumping the oil IMO.
GHO5T5NIPER is offline   Reply With Quote
Old 01-24-2014, 11:04 AM   #3
Should hold about 4 quarts maybe a little less
Old 01-24-2014, 11:04 AM   #4
Did you just run a hose down to the fill hole or did you use a funnel?
Old 01-24-2014, 11:09 AM   #5
Just used a funnel but make sure it is absolutely clean and be careful if with the shifter gasket, make sure nothing falls down in the tranny and you'll be fine
Old 01-24-2014, 11:10 AM   #6
Slow4V's Avatar
1. Jack car up
2. Get a 3/8 Rachet
3. Undo the drain bolt located under the transmission
4. Drain the fluid into a measure bucket to measure how much came out
5. Plug the drain back up
6. Remove shifter
7. Pour whatever came out, the amount
Into the transmission
8. Re install shifter with new silicone
9. Test drive
Old 01-24-2014, 11:10 AM   #7
Sweet!! I know what I'm doing this weekend! Thanks man!
Old 01-24-2014, 11:13 AM   #8
Good Luck! Btw what fluid u decide to use?
Old 01-24-2014, 11:14 AM   #9
Don't have it yet. What would y'all suggest?
Old 01-24-2014, 11:21 AM   #10
Royal purple is what I used. Expensive as hell but it shifts so much smoother
Old 01-24-2014, 11:22 AM   #11
Yeah that's what pretty much everyone has told me to get.
Old 01-24-2014, 12:03 PM   #12
Put in only 3.25 quarts to avoid any windage problems.
Old 01-24-2014, 12:34 PM   #13
Use Dex III fluid, helps cold shifting.
The way I've done it forever and never had a problem:
-Pull drain plug AND fill plug
-Let it all drain out completely (duh)
-Put the drain plug and ONLY the drain plug back in. DO NOT OVERTIGHTEN, I have seen cracked cases because some gorilla went nuts on it.
-Pop the shifter and pour fluid in through there, I don't use anything but good aim and a rag, you might want to use a funnel, however works best for you.
-Fill till fluid starts to spill out of the fill plug.
-Wipe up excess fluid, re-install fill plug/shifter, drive.
Old 01-24-2014, 05:56 PM   #14
Roguestang's Avatar
What about the beer part??!!!
Lol
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 01-24-2014, 06:02 PM   #15
Lol
Haha.
It goes without saying that you have a beer after each of those steps...
Old 01-24-2014, 11:32 PM   #16
-Don't pour beer into transmission. Also do not go for test drive after multiple beers. Also if you consider Bud/Miller/Coors/Keystone/Bush/Natty or any of the other macro pee "beers" as an actual beer please see me after class to turn in your man card.
Old 01-25-2014, 06:50 AM   #17
Roguestang's Avatar
Lol!
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
Transmission fluid - Edge 2001 sam62893 Pre-2005 V6 Mustang 36 12-16-2012 12:55 PM
TSB Transmission Fluid Change UPDATE pcarman 2011-2014 Mustang GT 11 01-10-2012 02:41 PM
Manual Transmission Fluid Napoleon85 2011-2014 Mustang GT 6 11-15-2011 02:47 PM
Best Transmission Fluid Stang23 2005-2010 Mustang GT 0 08-07-2011 12:48 PM
09:24 AM
