285 tires - Mustang Evolution
Old 01-24-2014, 05:03 PM   #1
XSlashDashX's Avatar
285 tires
Switched out rims with the white gt. Is 285 the largest i can go without removing the quad shocks? Or can I put 315s? 18x10.5 in rear. 98 GT.
Old 01-24-2014, 05:08 PM   #2
Slow4V's Avatar
I ran 295 no problem
Just had to roll fenders because I'm too low
Old 01-27-2014, 11:50 PM   #3
1996mustang's Avatar
Im running 285/40/17 on mine. No problem with the quad shocks here i clear them just good. You could do 315 however i probably would recommend spacer then just to be safe.
Old 01-27-2014, 11:57 PM   #4
EthanGT03's Avatar
Running 315s with 17x10.5 with no problems
EthanGT03 is offline   Reply With Quote
Old 01-28-2014, 12:01 AM   #5
How much space from the quad shocks? Pic if you got one would be awesome so as well as op i can see if its possible. And what offset?
Old 01-28-2014, 12:39 AM   #6
Currently running 265/35/18 front, 285/35/18 in rear.
Old 01-28-2014, 08:14 AM   #7
Slow4V's Avatar
Just upgrade your control arms and remove the quad shocks
Easy fix
Old 01-28-2014, 08:19 AM   #8
mystang50's Avatar
315's with quad shocks
Old 01-28-2014, 12:19 PM   #9
EthanGT03's Avatar
I can get a pic in a couple hours and I'll post it. The offset I believe is +27mm
Best all season tires? sLbxO143 Mustang Wheels & Tires 30 12-18-2013 08:13 AM
NMRA "Super 'Stang" rules and regulations rebeltx At the Track 4 03-06-2013 12:02 PM
First time at the track Brad598400 2011-2014 Mustang GT 34 02-05-2013 12:54 AM
tire question mattthegreat210 Mustang Wheels & Tires 15 11-03-2012 07:48 PM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 11:55 PM
09:06 AM
