OIL PRESSURE AHHHHH - Mustang Evolution
Old 01-25-2014, 10:29 AM   #1
OIL PRESSURE AHHHHH
okay so lately when I start my car my stock oil pressure gauge doesn't move, stays dead... then a little while later it shoots up to just past half where it usually would be. Is it just frozen cold or should I be concerned
KraftDinner is offline   Reply With Quote
Old 01-25-2014, 01:03 PM   #2
Mile high JDF's Avatar
How cold has it been getting where you're at? I know your other thread said Canada. What weight oil are you running?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-25-2014, 09:55 PM   #3
Old 01-27-2014, 08:51 AM   #4
The stock oil pressure gauge in the cluster is nothing more than an on/off switch that comes on at 6 psi. It is not accurate and you can have dangerously low pressure and nothing will alert you until your motor seizes.
With that said... if it is off you might have an oil pressure issue but more likely it is just a bad sender or the gauge itself is jacked. Best bet is to install an aftermarket oil pressure gauge that will tell you what pressure you are actually running.
2000 Mustang GT Steeda #0048
Old 01-27-2014, 09:05 AM   #5
I guess I can finally justify a pillar gauge pod
It does come on but not until the car is on for a few minutes.
Would my temp not shoot up if the car was about to sieze?
Old 01-27-2014, 09:10 AM   #6
How long have you been running it like this?
Old 01-27-2014, 09:16 AM   #7
couple weeks now . I was thinking it was just cold. Car sounds normal and the oil level is proper so I wasn't that concerned
Old 01-27-2014, 09:20 AM   #8
Roguestang's Avatar
I installed a oil pressure gauge for this exact reason. I would definitely check your oil level. Like scotty stated, the stock gauge only kicks on at 6 psi. So don't trust it, and also like he stated, how long has it been doing that?
As for seizing, if the pump is bad, it'll seize up for sure, if its from low to no oil, your timing chain tensioners could fail, bearings could scorch/break, rods could snap..etc...etc....
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 05:33 PM
First start up no oil pressure Bennyhill 2005-2010 Mustang GT 3 05-19-2013 02:46 PM
oil pressure Berbantor 1996-2004 Mustang GT 2 01-23-2012 12:01 PM
Oil pressure issues Klinton 1979-1995 Mustang GT 6 09-11-2011 02:52 PM
Fluctuating oil pressure? Pascullon Pre-2005 V6 Mustang 0 07-19-2011 09:20 PM
04:08 AM
