ABS question - Mustang Evolution
Old 01-25-2014, 03:39 PM   #1
ChicagoJoe's Avatar
ABS question
Ok, so I got my springs in, and in the process of installing them I cleaned off the speed sensors for the ABS system. Either it's coincidence or I goofed something cleaning the sensor but now the anti-lock light is staying on.
After some research I found that I could "pull" DTC's from the ABS system by shorting out the orange/white wire with the ignition off and then turn the ignition on and count the codes out. I "pulled" a 31 which is "right front ABS sensor continuity fault", so in order to double check to make sure that is indeed what the problem was I dismantled . Jacked up the right front, removed the wheel, removed the inner fender well, unplugged the sensor and tested for resistance I pulled a 1.6 K resistance. Here's my question, and my problem. I can find the resistance (1.2 - 2.0) for 1998 and up, but I have a 1997 So I'm not sure what resistances I should be looking for. Anyone know by chance?
Using Tapatalk
ChicagoJoe is offline   Reply With Quote
Old 01-25-2014, 04:12 PM   #2
Mile high JDF's Avatar
A continuity fault would lead to either too high of a resistance or too low. The ABS system theoretically should be the same for all the SN-95S (New Edge included). Can you clear the code and see if it comes back? If it comes back then either the sensor broke or a wire got torn in the process
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-25-2014, 04:58 PM   #3
ChicagoJoe's Avatar
just removed that battery leads to see if sitting overnight will clear them. I checked the wires and they are all fine. if the codes still there tomorrow I'll look for a pinout of the ABS wiring to test the continuity of the wires from the module to the sensors I guess. I just hate throwing parts at a car.
Using Tapatalk
Old 01-26-2014, 04:07 PM   #4
ChicagoJoe's Avatar
ok, so I went out today and tested everything I could think of. Pulled both front tires off and fender wells.
Tested the drivers side (sensor/wires/module)
  • Sensor Resistance: 1.646 K
  • Wire Continuity (Plug to sensor): Good
  • Wire Resistance (Plug to sensor): .001 K
  • Wire Continuity (Plug to module): Good
  • Wire Resistance (Plug to module): .001 K
  • Voltage at Module (see image): 4.72 V
Tested the passengers side (sensor/wires/module)
  • Sensor Resistance: 1.642 K
  • Voltage at Module (see image): 4.73 V
I didn't get a chance to test voltage though the wires to the sensor as it started raining. I'm at a loss. I'm pulling a DTC 31, I've checked it and that sensor seems fine. Unless it's an intermittent issue I'm thinking it might be the module it's self. I suppose I'll start throwing parts at it starting with a sensor because I can't find any specs for these sensors or the module so I have no idea what my findings are. I can say that the right and left sensors up front are reading basically the same so since one is good the other should be as well. Unless 1.646 is the lowend range lol.
If anyone has any ideas I would appreciate them cause I hate throwing money away, and I dont have much to throw to start with.
Thx, Joe
Forgot the Image! LOL
Using Tapatalk
Old 01-26-2014, 06:05 PM   #5
This is the first thread regarding ABS, since Ive been on here, that I can recall, where it actually seems that someone is truly interested in fixing the ABS, AND, seems capable of doing so.
It's all you ChicagoJoe. You're going to have to be the one to show us how it's done...
Mine doesn't work either, most of the time anyways. I suspect that its a wheel sensor on my car because the ABS light will turn off imediately after washing the car, then come back on after a while.
I've had no interest in fixing it...
It will be interesting to find out what is causing the problem with your car.
Old 01-27-2014, 07:24 AM   #6
tinezz82's Avatar
Region: Nevada
ChicagoJoe i have the same the problem as you, my ABS comes on only when its hot out side, for example now that its winter the ABS hasnt came on at all but once it starts warming up it will come on again. I took it to O'Reilly and was told the ABS module was bad as it was connecting to there scanner, so i will replace when i get the money as its about 2k to replace.
tinezz82 is offline   Reply With Quote
Old 01-27-2014, 11:46 AM   #7
ChicagoJoe's Avatar
I found another discussion on another mustang forum and a person used this guy on eBay that rebuilds the module. He had good results. If links to other stang forums are allowed let me know and I'll post a link.
Sent from my Nexus 5 using Tapatalk
Using Tapatalk
Old 01-27-2014, 01:00 PM   #8
I post links to other forums all the time and haven't gotten in trouble yet.
Old 01-27-2014, 01:36 PM   #9
ChicagoJoe's Avatar
OK then lol, here ya go. Seems like he had a good exchange going by the end of his post.
Using Tapatalk
Old 01-27-2014, 11:27 PM   #10
twotone01's Avatar
I'm having the same problem. I installed springs last week and yesterday my Yellow ABS light is on, so I pulled the code and I got C1145 which is "Right front wheel speed sensor input circuit failure" I haven't had time to test the sensor side resistance to check if it's in spec but I'm going to do so soon. One thing also I need to check is the air gap between the sensor and the ABS ring on the hub, might be too big
twotone01 is offline   Reply With Quote
Question regarding exhausts and intakes crev 2011-2014 Mustang GT 7 08-22-2013 09:11 AM
New '14 Owner with lowering question Evil2014GT 2011-2014 Mustang GT 10 04-11-2013 02:46 PM
Exhaust question Codysmustang 1996-2004 Mustang GT 14 11-21-2011 09:11 PM
Kenne bell 2.6L question Ahmed ali khan 1996-2004 Mustang GT 4 11-14-2011 12:54 PM
Mach 1 ABS module help! DaBluedude SVT Mustang 11 11-07-2011 06:48 AM
03:03 AM
