abs light - Mustang Evolution
Old 01-31-2014, 06:50 PM   #1
Tangtang2.0's Avatar
abs light
so i turned on my car and the abs light stayed on then i drove it for around 10 min and it turned off and then it turned on again and after a couple of minutes it turned off haha .. any ideas of whats happening3
Tangtang2.0 is offline   Reply With Quote
Old 01-31-2014, 06:57 PM   #2
Funny we both have a 2000 GT ... I just realised after reading this that I have never seen my abs light lol even when I slam my breaks... pretty sure I don't have abs
KraftDinner is offline   Reply With Quote
Old 01-31-2014, 06:59 PM   #3
lol i didnt even break hard.. just randomly turned on
Old 01-31-2014, 07:05 PM   #4
04beautyGT's Avatar
Does it only come on when braking? If so, there's 95% chance of it being low brake fluid. I know I had to tighten my bleeder valve pretty tight to stop my leak.
If you have good brake fluid, then I don't know what to tell you, it could be a lot of things like from your master cylinder to an electrical problem.
04beautyGT is offline   Reply With Quote
Old 01-31-2014, 07:09 PM   #5
my battery light has been turning on and off all day.. my car hasnt been on for a week and today was my first day driving it do you think it could be that?
Old 01-31-2014, 07:28 PM   #6
Mile high JDF's Avatar
Might want to get your alternator checked if the battery light is coming on. I believe I remember hearing about people having ABS and other electrical issues due to the alternator going out
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-31-2014, 07:28 PM   #7
that I do know the answer to .. If your BATTERY light comes on, its an issue with your alternator!.. check your belt and if that's good replace your alternator... The only way the battery light will come on is if your alternator is not working.
Old 01-31-2014, 07:34 PM   #8
will do guys thanks for the tips
Old 02-03-2014, 06:10 AM   #9
Okay so the abs light hasn't come on for a while but the battery light turned on when I accelerate... Could it be the alternator?
Old 02-03-2014, 10:06 AM   #10
Slow4V's Avatar
Everybody 99-04 has abs lol
Do you guys even know what the abs system is even for? Or how it operates ?
---------- Post added at 12:06 PM ---------- Previous post was at 12:05 PM ----------
Battery and Alt test are free
It's very simple to get them diagnosed
Old 02-03-2014, 10:31 AM   #11
Mfore33's Avatar
My alternator diode regulator failed. You can get a kit to replace it for way less than a new alternator.
Old 02-03-2014, 10:31 AM   #12
TylerJanocha21's Avatar
Get a new alternator, my 98 GT had the same problem with the battery light when I bought it
TylerJanocha21 is offline   Reply With Quote
Old 02-03-2014, 10:33 AM   #13
Mfore33's Avatar
And system has sensors on each wheel that measure the speed of each wheel. You could have a sensor going bad or in my case the abs module was going bad. My abs light has been on for 7 years now. I didn't want to spend the money for ford to fix it. Haven't had any problems stopping.
Old 02-05-2014, 12:14 PM   #14
Okay so when the abs light comes off the traction control turns off is that normal?
Old 02-05-2014, 12:22 PM   #15
Yes.
The traction control receives its information from the ABS.
If the ABS is malfunctioning, the traction control won't work...
Old 02-05-2014, 12:40 PM   #16
bucko's Avatar
Before you go and start tossing parts at a fault, do yourself and your wallet a favor and get the charging system checked...for free. Most automotive parts stores will perform a load test on your battery, and your alternator. You may be asked to remove the alternator first, but you'd be doing this anyhow if you (or someone else) was going to replace it.
Sure, check the simple stuff first, like the belt, battery connections (clean connections?), then start suspecting the battery and/or alternator. But have them load tested first before replacing.
Old 02-05-2014, 01:05 PM   #17
Okay I'll go get it checked.. I just replaced the battery. Couple months ago if something's up could be belt or alternator
Old 02-06-2014, 07:34 AM   #18
Steve96's Avatar
My ABS does the same thing. It comes on and off. Brake fluid is full, master cylinder is good, alternator and battery are good. Car stops great, no issues. As slow said Almost all 96-04 cars have this issue at some point it must be a sensor acting up. I would get everything checked to be sure that It's not something else and just drive it.
1996 GT
Old 02-06-2014, 09:50 AM   #19
yellowconve's Avatar
i have a similar problem mine is always off it also has been skidding so im guessing the anti lock is not working the light always says off and when i click it nothing happens light stays the same >< ??????
yellowconve is offline   Reply With Quote
Old 06-05-2014, 07:10 PM   #20
Ok I know this is old, I got my battery and alternator checked there's nothing wrong now, what could I do next to try to fix the abs light I'm looking to sell the car in a couple days and I wanna know what I have to do to turn off the abs light
Old 06-05-2014, 09:39 PM   #21
Steve96's Avatar
I've had this ABS light thing before. It did after installing all my lowering components. I had the ABS system checked and it checked out fine. Mechanic said it was most likely a faulty sensor. My ABS worked fine when I checked it (slamming on the brakes). That was over a year ago, it did it a few times and now hasn't for almost a year.
1996 GT
Old 06-05-2014, 10:09 PM   #22
Left rear speed sensor
ABS light + traction control doesnt work RedGT04 1996-2004 Mustang GT 16 11-12-2015 06:43 PM
ABS Light is on. jubileephoto 1996-2004 Mustang GT 6 11-30-2011 01:22 PM
Abs light? Gigerdavid 1996-2004 Mustang GT 3 10-30-2011 11:47 AM
ABS and Track off light On Siendly22 General Mustang Discussion 1 10-18-2011 05:19 PM
ABS light on and track off Siendly22 2005-2010 V6 Mustang 0 10-13-2011 11:51 PM
04:00 PM
