2001 gt - Mustang Evolution
Old 02-02-2014, 05:47 PM   #1
Thunderupokc81's Avatar
2001 gt
I am about to buy a cam for my 2001 gt. Does anyone have any suggestions on a good cam that will give me peak performance? Pretty much stock engine except for a Bbk cold air and Bbk pulleys and performance ignition and a tune and Flowmasters.
Thunderupokc81 is offline   Reply With Quote
Old 02-02-2014, 05:48 PM   #2
Oh and is there anything else I should get with the cam for better performance?
Sent from my SAMSUNG-SGH-I537 using Mustang Evolution mobile app
Old 02-02-2014, 06:06 PM   #3
U shud git geerz 1st.
CamZ moov ur pwrb@nd up n tayk sum lw3r 3nd oot of da ngine
Sent from my Barbie Dream Phone®
CoolHorsey is offline   Reply With Quote
Old 02-02-2014, 07:11 PM   #4
Ok I'll get gears too! 3.73 or 4.10? Still gonna get a cam.
Old 02-02-2014, 07:20 PM   #5
Mile high JDF's Avatar
I would research cams more before settling on them as your next upgrade. You will benefit most with cams on a N/A motor by making sure you've got enough air coming in and moving out at a good rate. Most cams have gear recommendations that go with them as well. I would recommend at least upgrading your intake plenum and throttle body. Cams aren't cheap to install either
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-02-2014, 07:57 PM   #6
Thanks great advice
Old 02-03-2014, 07:46 AM   #7
You have 2 cams, not 1. New ones are $600 plus $150 for the degree service and you will REQUIRE a tune afterwards so add another $400-$600. For that sort of money there are a LOT of other bolt ons you can do to improve performance.
Old 02-03-2014, 08:14 AM   #8
mystang50's Avatar
x2! you need two not one lol
Old 02-03-2014, 09:59 AM   #9
Slow4V's Avatar
Swapping cams isn't like the old ford
GTs have over head camshafts which require you to mess with the timing chains.
Just a heads up
For a NA setup with really no bolt ons you'll probably get like 5-15hp tops
Now if you had full bolt ons, and what not you'll see a lot better gains
Old 02-03-2014, 12:10 PM   #10
Yes I know there is two cams!
---------- Post added at 01:10 PM ---------- Previous post was at 01:09 PM ----------
Ok give me some bolt ups I can get
Old 02-03-2014, 01:05 PM   #11
There's a huge sticky about bolt ons at the top of the forum.
Dropping in a 2000 gt motor Blackedout Pre-2005 V6 Mustang 20 02-07-2012 09:48 PM
2005 Mustang GT 350 Tribute Car (Mineral Grey Lovers) 2K05GT Pictures and Videos 8 02-01-2012 04:43 AM
1966 Ford Mustang GT Fastback Raffle to Protect Children jdipietro ME Site Help & Announcements 1 07-01-2011 04:43 PM
» Members Mustangs
Twister
Janet H
Pig
gtcpa
Add your Mustang
02:52 AM
