2004 Mirror shake fixed !!!! - Mustang Evolution
Old 02-05-2014, 02:18 PM   #1
2004 Convertable: Vibrating driver's mirror. Problem solved.
If you can remove the mirror glass assembly(glass and plastic backer) without breaking the little fingers, you can fix it.
Run the mirror all the way in on the inside and out on the outside. Pry the fingers loose very carefully with a long thin common screw driver until you have enough free to get it off.
The problem: See the round groove in the round foam pad? That is the problem. The foam is suposed to take up the slack. It gets old and a groove appears.
The solution: Very carefully pry the foam rubber pad loose. Very carefully fill just the groove with silicone rubber. No extra. flip the pad and put the foam pad back on the mirror silicone side down now. The silicone is the "glue and groove filler. Center the foam pad and smooth it out. Let it dry. Now very carefully "click" the glass and backer back in place aligning the notch and keys top and bottom first. Press firmly, don't drop it.
Done.
BritCarDoc is offline   Reply With Quote
Old 02-05-2014, 03:39 PM   #2
Slow4V's Avatar
Would love to see some pictures of the process to help understand
But cool
Old 02-05-2014, 04:11 PM   #3
DaBluedude's Avatar
I would also like pics. This drives me nuts on my Mach!!
2003 Mach 1
Old 02-05-2014, 08:20 PM   #4
Too late, I'm not going to risk the tabs by taking it apart again. Sorry
Old 02-09-2014, 06:06 PM   #5
1lowGT's Avatar
Very common problem. If I ever do it i will try to follow his words and make a guide with pics
Old 02-09-2014, 09:00 PM   #6
The mirrors on my Expy and my Stang do the vibrate thing, will have to yank the one off the Expy and see if I can tell what he is talking aboot.
Old 02-09-2014, 09:34 PM   #7
94gtconvert's Avatar
This is great info, I will definitely be doing this when it gets warmer out.
94gtconvert is offline   Reply With Quote
2004 mustang price secomejia 1996-2004 Mustang GT 28 01-05-2012 09:19 PM
2004 cobra wighes 4k?? Driftfiend General Mustang Discussion 6 11-18-2011 12:56 PM
2004 3.8 stalled out and won't restart chrissiesstang Pre-2005 V6 Mustang 5 11-05-2011 10:01 AM
2004 40th Anniv conv. Crystal Pre-2005 V6 Mustang 11 09-09-2011 07:48 PM
07:07 AM
