Grinds into reverse - Mustang Evolution
Old 02-06-2014, 01:36 AM   #1
Rich04's Avatar
Grinds into reverse
To get my car into reverse i have to go into first let off the clutch a little then throw it in reverse. It grinds any other way, this normal ? Cause it never happened before
Rich04 is offline   Reply With Quote
Old 02-06-2014, 06:16 AM   #2
HighlyBored's Avatar
My 2001 does the same thing. Impossible to just get it in reverse normal. Usually I just have to put it in 5th and then it'll slide right into reverse. If that doesn't work I have to put it in first, pull forward, and then put it in reverse.
From my understanding it's a fairly common problem with new edge GTs. Plus I have the early 2001 so I have the ****ty tranny on top of that.
HighlyBored is offline   Reply With Quote
Old 02-06-2014, 07:16 AM   #3
Slow4V's Avatar
Same with mine I have to go into 1st then reverse
Old 02-06-2014, 09:14 AM   #4
Roguestang's Avatar
Mine grinds too. I usually give it a little gas with the clutch pushed in, and sometimes, she'll go right into gear and other times it still grinds. Or like mentioned before, I go into 5th, then it goes right into reverse.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 02-06-2014, 10:06 AM   #5
JetLife 01GT's Avatar
+1 for pulling forward slightly in first and then reverse. if i slowly and gently slide it into reverse usually works with no grind
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 02-06-2014, 11:12 AM   #6
Mfore33's Avatar
Maybe it is caused by slack in the shift linkage. That might cause a bind and when you shift into 1st or 5th that unbinds the linkage allowing you to get into reverse.
Old 02-06-2014, 03:49 PM   #7
Rich04's Avatar
I have a T56, is it common for them aswell?
Old 02-06-2014, 05:09 PM   #8
Roguestang's Avatar
My buddy says his does in his Z28 too.
Old 02-06-2014, 05:13 PM   #9
Butch's Avatar
Region: New Mexico
After I had my rebuilt it started to do that sometimes. Other time I have to threaten it with death to go in
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 02-06-2014, 05:57 PM   #10
Geiger's Avatar
My '04 did that too
2008 GT/CS , 17k original miles, bagged with airlift v2, cammed, and some bolt ons.
Geiger is offline   Reply With Quote
Old 02-06-2014, 06:13 PM   #11
I believe the consensus is that every new edge ever built does this.
Old 02-06-2014, 06:18 PM   #12
Butch's Avatar
Region: New Mexico
Not mine before the rebuild. It was smooth as butter.
-----NEHP---
{Never Enough HP}
Old 02-06-2014, 06:19 PM   #13
Ok.
Everyone but butch.
Old 02-06-2014, 06:20 PM   #14
Butch's Avatar
Region: New Mexico
Ok.
Everyone but butch.
=ΒΆ or not
-----NEHP---
{Never Enough HP}
1st to 2nd gring and reverse issues runvsofthisbull 1996-2004 Mustang GT 3 08-21-2012 01:40 AM
Reverse trouble JetLife 01GT 1996-2004 Mustang GT 5 12-09-2011 02:14 PM
reverse glow gauges Codysmustang 1996-2004 Mustang GT 7 11-23-2011 07:29 AM
Reverse at 65 mph V6Mustang40th Pre-2005 V6 Mustang 4 10-28-2011 02:41 PM
Reverse glow gauges not working! Jordan Pre-2005 V6 Mustang 24 10-05-2011 09:22 PM
10:48 PM
