Big Trouble Brakes - Mustang Evolution
Old 02-07-2014, 07:04 PM   #1
Michael.s.king's Avatar
Region: Maine
Big Trouble Brakes
I went to go replace my rear pads and rotors because one was grinding. First of all, those clip things on the pads are a pain in the ***. Then I noticed one of the boots was missing from one the caliper rod things. So I assume this has been sticking. I also assume the only way to fix this is to get a new caliper and a new caliper for the other side as well, so the two calipers will have the same stopping power?
This is really expensive to get two new calipers and its just something I can't afford right now. Anything else I can do? Please let me know thanks guys I appreciate the help!
Michael.s.king is offline   Reply With Quote
Old 02-07-2014, 07:33 PM   #2
NewMtang's Avatar
Get the Fred Flintstone Brakes.
Old 02-07-2014, 07:55 PM   #3
Region: Maine
Hahah thanks man
Anyone know if it's possible to lube up the bolt and put a new boot on it? Would it wear uneven still because one bolt is better than the other? Sorry for the painful questions
Old 02-07-2014, 08:47 PM   #4
Mfore33's Avatar
You can buy a new set of slide pins with boots. It's a brake hardware kit.
Old 02-07-2014, 08:52 PM   #5
Region: Maine
Where at? Any parts store? Thank you!
Old 02-07-2014, 10:03 PM   #6
Any parts store should have the brake hardware.
Old 02-07-2014, 10:20 PM   #7
escottcarp's Avatar
I got the kit for about $15 last summer... I believe at O'Reillys. But, all parts stores carry it. Just be sure the kit included the items you need.
escottcarp is offline   Reply With Quote
Old 02-07-2014, 10:21 PM   #8
escottcarp's Avatar
Be sure to get the brake grease, too.
Old 02-08-2014, 07:54 PM   #9
Rejekt's Avatar
Late model restoration carries the brake hardware kit
Sent from my LG-LS720 using Mustang Evolution mobile app
Rejekt is offline   Reply With Quote
Old 02-08-2014, 07:57 PM   #10
Rejekt's Avatar
http://www.latemodelrestoration.com/...e-Hardware-Kit
Old 02-09-2014, 02:28 PM   #11
escottcarp's Avatar
If your slide pin is rusty, you can sand it smooth with 400 grit sandpaper. That's what I did. You still need the brake grease.
Old 02-10-2014, 10:16 PM   #12
Region: Maine
So I got the brake hardware kit (for the boots and the clips) and I also got new guide pins. It was a nightmare trying to get my old guide pins off but I eventually got it done with a blow torch and everything seems to be fine! Like $15 for the hardware kit and new guide pines. So glad I didn't have to get a new caliper and everything. Thanks guys!
Old 02-10-2014, 11:02 PM   #13
NewMtang's Avatar
Talking On the Road Again....
Glad you were able to get the parts without paying a fortune for the parts.
New Brakes Timm04 Pre-2005 V6 Mustang 6 09-22-2011 01:28 PM
2010+ Mustang with Brembo Brakes msgt46270 2011-2014 Mustang GT 2 09-13-2011 09:47 AM
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
Brakes mcvicar04 1996-2004 Mustang GT 12 08-15-2011 06:18 AM
rear disc brakes swap wss003 1979-1995 Mustang GT 6 07-24-2011 01:46 AM
04:20 PM
