Powersteering help! - Mustang Evolution
Old 02-07-2014, 09:53 PM   #1
TylerJanocha21's Avatar
Powersteering help!
I got in my car this afternoon and noticed when my car idles it doesn't have powersteering but when I rev it up a slight bit it'll work fine until I let it idle again, also while trying to turn it while sitting still it starts to make grinding noises and such.
TylerJanocha21 is offline   Reply With Quote
Old 02-07-2014, 10:12 PM   #2
Roguestang's Avatar
Check your fluid level. Sounds like its really low, which could mean a leak, or a faulty pump
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 02-08-2014, 03:55 PM   #3
Fluid level was low so there probably is a leak somewhere
Old 02-08-2014, 05:01 PM   #4
Roguestang's Avatar
Check the hoses leading into the steering rack and into the pump. If its ever been taken off before, chances are someone over cranked the bolts and its not tight
Old 02-08-2014, 07:26 PM   #5
10-4 thanks I'll check it in the morning, thanks
Old 02-08-2014, 08:00 PM   #6
Slow4V's Avatar
Probably high pressure hose leaking or rack and pinion.. Most common
Better NOT run with low or empty power steering fluid, if you keep being lazy you will end up buying a powersteering pump, rack and pinion, and alignment like my idiot self
Old 02-08-2014, 09:25 PM   #7
Yeah I'll head out with my dad and look for the problem tommorow the fluid was at the minimum mark and I filled it back to normal levels
Old 03-12-2014, 12:56 PM   #8
Just came across this thread again, hoses weren't leaking and I narrowed it down to the power steering pump going bad
Old 03-12-2014, 02:00 PM   #9
Roguestang's Avatar
Thanks for the follow up!
What does it cost to repair power steering for a 2002 mustang? delmon 1996-2004 Mustang GT 2 04-01-2013 12:09 PM
Powersteering pump problem!!! Frankensteins 1996-2004 Mustang GT 1 01-09-2012 05:35 PM
Powersteering pump jhagan1980 1979-1995 Mustang GT 5 07-06-2011 10:05 PM
07:34 PM
