Is it worth it - Mustang Evolution
Old 02-10-2014, 11:07 PM   #1
04sonicbgt's Avatar
Is it worth it
Recently discovered I'm having some head gasket issues, I have 143,xxx on the motor what I'm wondering is if I'm gonna take the heads off,etc. to replace gasket should I just upgrade heads/cams while I'm there (mhs stage 2 package) will this be worth it with that many miles?
Sonic blue 04 GT~~bolt ons- headers, steeda tri ax, hi tech stage 2 cams coming this winter.
04sonicbgt is offline   Reply With Quote
Old 02-10-2014, 11:14 PM   #2
I would say yes, if that's the route that you want to go and you can afford it.
Those miles aren't too bad as long as it has been maintained reasonably well.
Old 02-11-2014, 09:11 AM   #3
1lowGT's Avatar
If you are going to have the heads off and can afford other stuff I would get cams and port the heads while they are off
Old 02-11-2014, 10:58 AM   #4
saleenfan04's Avatar
If you have the money then yes it be worth it
saleenfan04 is offline   Reply With Quote
Old 02-11-2014, 02:09 PM   #5
1lowGT's Avatar
It'll be pricey. By worth it.
Old 02-11-2014, 07:10 PM   #6
Mfore33's Avatar
I would think if you have to pull the heads then you might look into a rebuild of the bottom end as well. I would hate to malt the top end brand new and the bottom let go shortly after. At least get it looked at and see what condition the bottom end is in. Best of luck.
Old 02-12-2014, 07:43 AM   #7
1lowGT's Avatar
Good advice^ might as well tear it down and build it. Unless money is an issue which is why I'd just cam it and new gasket. But that still is gonna run over 2k probably if you get new springs retainers and what not and to install/degree.
Lake Worth GTG (Fort Worth, TX) bigmac3 Regional Mustang Discussion 1 02-13-2014 03:28 PM
Are drag bags worth it? Luna1994 General Mustang Discussion 1 01-23-2014 05:37 PM
Not sure what these are worth.... Naut 1979-1995 Mustang GT 6 04-30-2013 04:30 PM
SLP long tube headers, worth the money? leviz79 1996-2004 Mustang GT 7 12-18-2011 10:13 PM
Is it Worth it jjsg09 1996-2004 Mustang GT 14 10-14-2011 12:26 PM
06:45 PM
