Does any1 knows? - Mustang Evolution
Old 02-11-2014, 06:53 PM   #1
saleenfan04's Avatar
Does any1 knows?
Hi, does anyone knows how much hp 03 gt engine can handle? Camshaft, piston, etc....
M goal is to get 480hp without breaking anything thank you.
saleenfan04 is offline   Reply With Quote
Old 02-11-2014, 07:02 PM   #2
Mile high JDF's Avatar
450whp is about the max you wanna push these bottom ends. After that you'll want to start upgrading your rods and pistons at least, the cranks are good for mid to high 500whp
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-11-2014, 09:07 PM   #3
450 is when upgrading the internals should be on your mind all day and when sleeping. I personally wouldn't go past 420 on stock internals.
Old 02-11-2014, 09:19 PM   #4
Where can I buy internals? not so expensive lol how much would it cost me to install them? Do I need to rebuild my rear end or it be fine?
Old 02-11-2014, 10:17 PM   #5
DSS Racing, MMR, all sorts of companies make kits it just depends on what you're looking for. As for the rear end it depends on what you plan to do with the car
Old 02-11-2014, 10:39 PM   #6
Most of the time daily driving but on weekend track. Is this all I need
:MMR I beam Forged Rods, Manley Forged Pistons, Chromoly Piston Pins, Total Seal File Fit rings up to 750 HP
Old 02-12-2014, 03:35 PM   #7
That's a start. The stock crank will need upgrading plus machining the block before installation.
Don't forget getting the rotating assembly balanced. Expect a machine shop bill around $1500 for that. Another $500 for assembly.
Stock heads will be your next limit. $4500 heads plus $3000 in cams/retainers/chains.
Add another $650 for removal and install of motor plus $350 for dyno time and tuning.
Sent from my massive johnson.
Old 02-12-2014, 05:35 PM   #8
Dang that's lot I was thinking about around $2000 but nvm I probably stay around 420 with 2.1 kb thx for the info
Old 02-12-2014, 05:51 PM   #9
The thing is you can do it cheap now but eventually you'll have to pony up the money. We haven't even gotten into fuel system, trans, rear or suspension.
Old 02-12-2014, 05:54 PM   #10
Damn, I don't want to see more numbers lol what about 2.1 kb with 9psi? I don't need to change anything then right?
Old 02-12-2014, 05:58 PM   #11
Fuel system? With a conservative tune it should be ok for a little while but it will blow. Just part of the game.
Old 02-12-2014, 08:31 PM   #12
In the case should I get fuel control or new fuel pump? Do I need to change my fuel lines?
Old 02-12-2014, 10:39 PM   #13
Fuel pump and injectors and maf
Sent from my Barbie Dream Phone®
CoolHorsey is offline   Reply With Quote
Old 02-12-2014, 11:11 PM   #14
1lowGT's Avatar
Low are you sure you're talking about 2v cams? 3k for all that? Maybe 2k after parts and install
---------- Post added at 12:11 AM ---------- Previous post was at 12:10 AM ----------
A shop here installed 4v cams 2k after all parts and install so I find It hard to believe 3k for 2v cams
Does any1 know how much horsepower can the internals of 1996 3.8l take?? M_PZoe Pre-2005 V6 Mustang 16 12-19-2011 09:37 AM
Does any1 know bout custom exhaust would sound like M_PZoe Pre-2005 V6 Mustang 14 12-18-2011 08:49 AM
04:38 PM
