4v head swap or trick flow heads? - Mustang Evolution
Old 02-12-2014, 07:04 AM   #1
brownr0311's Avatar
Hey everyone I have an 02 gt 2v I got a guy selling 4v heads out of an 01 cobra w/ 03 cobra cams for 400$ this includes the timing chain and etc... But would a 2v trick flow twisted wedge give me more power?
brownr0311 is offline   Reply With Quote
Old 02-12-2014, 07:46 AM   #2
1lowGT's Avatar
You have a budget?
Old 02-12-2014, 07:47 AM   #3
brownr0311's Avatar
Not really as long as it's some what reasonable
Old 02-12-2014, 07:58 AM   #4
2300turboford's Avatar
Trick flow heads are 2100 dollars
Old 02-12-2014, 08:04 AM   #5
brownr0311's Avatar
Which setup is the best? As far as power
Old 02-12-2014, 08:19 AM   #6
Trickflow out of the box flows better and saves the aggravation of swapping to a 4v but a very well ported 4v heads will out flow the trickflows
Old 02-12-2014, 08:22 AM   #7
That topic is beat to death they have their pros and cons. What exactly are you doing? Stock bottom end? Budget? Goals? "Reasonable" budget for one person is completely different for another person. You will likely spend nearly as much on 4V heads in the end as the TFS heads new or at least a set of good ported PI heads. The Terminator cams are not anything to write home about anyway, the 96-98 Cobra cams were the best OEM 4V cams.
Old 02-12-2014, 08:26 AM   #8
4v b heads flow 230/145 cfm @500 lift
4v c heads flow 225/145 cfm @ 500 lift
03/04 cobra heads 223/168 cfm@ 500 lift
2v pi heads flow 209/180 cfm @ 500 lift
Trickflow 2v 250cfm/190cfm@500 lift
Old 02-12-2014, 08:27 AM   #9
+1
Old 02-12-2014, 10:11 AM   #10
Don't you actually LOSE hp doing a 4v swap on a 2v?
I BELIEVE it brings the compression ratio down losing hp. But if you add a supercharger while your at it, that will be perfect lol
Sent from my Barbie Dream Phone®
CoolHorsey is offline   Reply With Quote
Old 02-12-2014, 10:22 AM   #11
brownr0311's Avatar
Thanks guys
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
Trick flow street heat intake..which heads AgPilot 1979-1995 Mustang GT 4 08-29-2012 01:11 PM
Trick flow 170 heads 04machazblue 1979-1995 Mustang GT 20 02-22-2012 02:53 PM
Good Information Thread. ESG642T Pre-2005 V6 Mustang 10 01-13-2012 08:00 AM
Cumbustion chamber size Mustang1968kr 1979-1995 Mustang GT 2 08-23-2011 11:51 AM
07:59 PM
