1997 gt rattle noise under car - Mustang Evolution
Old 02-13-2014, 05:23 PM   #1
9stan5's Avatar
How you fellas doing.theres this really annoying rattle noise like little rocks in a tin can I snap a pic of it but not sure if it's a muffler or cat.its both left and right.i wanna get rid of it or fix it before it worsens.Click image for larger version
Name:	ImageUploadedByMustang Evolution1392337343.453277.jpg
ID:	147792Click image for larger version
Name:	ImageUploadedByMustang Evolution1392337372.251894.jpg
9stan5 is offline   Reply With Quote
Old 02-13-2014, 09:22 PM   #2
1996mustang's Avatar
Check the flanges that connect the muffler to x pipe or h pipe. Mine had a rattle ended up being the flanges shook the bolts loose. Tightened them up all good. If you scrape the exhaust that also will cause them to loosen.....personal experience there lll
Old 02-13-2014, 10:02 PM   #3
Dakota05's Avatar
Check your hangers where the exhaust is hung from the car, the bushings can wear out over time, hope ya find what the rattle is!
Dakota05 is offline   Reply With Quote
Old 02-13-2014, 10:34 PM   #4
04beautyGT's Avatar
If you didn't put the exhaust on yourself...my brother found a bolt INSIDE of the muffler, how someone does that I don't know, but it can happen.
Either way, I would start by knocking on the mufflers, and try to follow the sound and notice if it only rattles when you push up (that could be a loose bolt).
04beautyGT is offline   Reply With Quote
Old 02-14-2014, 12:01 PM   #5
If those are flowmasters (look like it) the baffling inside the muffler can sometimes break loose and it will make the exact sound you are describing. Only fix is to replace the muffler. Luckily, dronemasters are not expensive.
Old 02-15-2014, 04:33 AM   #6
9stan5's Avatar
Yes does are flowmasters.ive looked them up and they have the same ones at advanced auto parts for about 80
Why are they called dronemaster?
Old 02-15-2014, 06:58 AM   #7
Look on summit and jegs before you look at advanced, might be cheaper. They're called dronemasters because at 2200 rpm on the highway you want to kill yourself because of the noise in the cabin.
Old 02-15-2014, 08:23 PM   #8
9stan5's Avatar
Yea they're actually cheaper.since im looking to remove them soon what will be a recommended brand without breaking the bank?
Old 02-15-2014, 11:06 PM   #9
Honestly the Summit mufflers get good results and are like $20/muffler. If you want a stainless straight through muffler its $100+ per muffler minimum.
Old 02-15-2014, 11:09 PM   #10
9stan5's Avatar
Sounds good.I just realized what the dronemaster name comes from around 2000-2500 there a really loud annoying noise.
Old 02-15-2014, 11:13 PM   #11
I had a moment where the light bulb clicked on when I owned my 91GT. It was after a 2 hour drive home to my parents house when I had just joined the military and wound up stationed one state over. Anyway I get out of the car and my Dad comes up and starts talking to me and I have a hard time hearing him for a few minutes. Not making this up and I worked/still work around operating jet engines for a living so I'm not some office weiner who can't stand loud noises.
Old 02-15-2014, 11:15 PM   #12
9stan5's Avatar
Are the summit muffler for both left and right since I need to get both or are thru reversible?
Old 02-15-2014, 11:21 PM   #13
Should be universal but double check, I can't remember 100% off the top of my head. Youtube has videos of how they sound on modulars too. Chambered is like a flowmaster, "turbo" is a straight through like a Magnaflow.
Old 02-17-2014, 10:53 PM   #14
9stan5's Avatar
So I went to a shop got the car lifted and banged my mufflers.turn out there both broken in the inside coming from the rattle inside.There charging 40 piece to install mufflers I bring.He also mentioned I have 2 cats missing
Old 02-18-2014, 09:03 AM   #15
Refer back to post #5 that I made where I diagnosed your exact problem for free over the interwebs. You have 2 cats missing because all aftermarket catted pipes only have 2 cats. You don't need 4 that come on the 5.0s or 6 on the Modulars.
As long as you have cats on there you are good. If not, some shops will not work on the car or even worse, not let the car leave the shop with an offorad pipe on there. Legally they actually are not supossed to allow a car with an offroad pipe go.
The Evolution/Future Build of My Car (Tons of Pics and Vids) DutchManDann 1996-2004 Mustang GT 90 08-01-2017 09:52 AM
1997 gt engine oil 9stan5 1996-2004 Mustang GT 7 02-11-2014 09:09 AM
First time at the track Brad598400 2011-2014 Mustang GT 34 02-04-2013 11:54 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
05:07 PM
