Fouled Plugs , Oil Low , Idle Issue - Mustang Evolution
Old 02-17-2014, 11:36 AM   #1
Slow4V's Avatar
So my buddy who did the 4V swap just sold it to my other friend for 6k which I think is a rip off ..
Anyways the new owner is noticing when we comes to a stop the car dies..
No codes ..
Also he checked the oil and it was barely on the dipstick
I witnessed them put the correct oil into the car.. No leaks, new seals..
Internal oil consumption ?
Also they replaced the plugs too, but they are all black and fouled..
Any ideas ?
I need real tech opinions
I figured maybe It's one of these ..
A piston has low compression
Incorrect valve timing problem
A damaged cylinder head
Air / fuel problem
Incorrect gap on plugs maybe
Old 02-17-2014, 11:51 AM   #2
Tyoung68's Avatar
It could be all these but my guess if the is oil on plugs then you have bad rings or bad valve guid/seal id run a compression test to it if you find a bad one if you pit about a cap (the cap from a quart of oil) of oil into the cylinder and the compression improves then your position rings are bad and of it doesn't then you have a bad valve. And if the all are fine id take the valve covers off and check the valve stem seals
Old 02-17-2014, 12:01 PM   #3
Slow4V's Avatar
Are the valve stem seals that easy to access ?
I need to change mine too lol
Old 02-17-2014, 12:05 PM   #4
Tyoung68's Avatar
Ummn tbh i have no idea haha iv only put them in when i rebuilt my engine you would have to take you valves off
Old 02-17-2014, 12:40 PM   #5
Slow4V's Avatar
Yeah just realized how much work is needed, forget that
Old 02-17-2014, 03:02 PM   #6
Tyoung68's Avatar
the springs not valves
Old 02-17-2014, 03:04 PM   #7
Slow4V's Avatar
I replaced springs once on a pushrod heads , never again.
Old 02-17-2014, 04:22 PM   #8
Tyoung68's Avatar
Ha its not that hard on pushrods just take the rocker arm off and get a over head valve spring compressor
Old 02-17-2014, 04:39 PM   #9
Tyoung68's Avatar
Old 02-17-2014, 05:11 PM   #10
cliffyk's Avatar
No mystery, the engine is shot--run dry and wet compresion tests, and a vacuum test, and you be able to find out just exactly what is wrong...
Old 02-17-2014, 07:10 PM   #11
Is this the engine where it had like 130k miles on it?
Old 02-17-2014, 08:48 PM   #12
Slow4V's Avatar
Yes scot
Well the plugs were fine they were gapped to .62
I re gapped them to 0.54
I cleaned out the IAC
And it did okay, but started acting up bad and kept dieing
After driving for a lil bit it stops turning off ,
Also it's VERY hard to get into gear , it feels like the cable isn't engaging correctly , and grinds sometimes
And does not want to go into gear at high rpms
Also they did the steering shaft but man it feels so loose, and feels like I'm driving a boat .. It wiggles side to side big times, doesn't feel good at all..
Old 02-18-2014, 06:30 AM   #13
And dude paid $6k for it? You might need to mediate some sort of refund if they are both friends...
Old 02-18-2014, 06:49 AM   #14
Slow4V's Avatar
Exactly what I told him
Old 02-18-2014, 09:10 PM   #15
Slow4V's Avatar
Well I fixed the transmission issue
I replaced quadrant with a steeda one and adjusted the clutch cable. Man world of a difference.
Stock quad teeth were rounded out
Now to figure out the idle issue
Old 02-18-2014, 09:12 PM   #16
Tyoung68's Avatar
Have you tires to clean all the air sensors or throttle body? Or check for vacuum leaks?
Old 02-18-2014, 09:35 PM   #17
It's probably the original IAC. Cleaning it does no good if it's worn out...
Old 02-18-2014, 09:37 PM   #18
Tyoung68's Avatar
Well only one way to find out haha
Old 02-19-2014, 02:48 PM   #19
Slow4V's Avatar
Well wouldn't it throw a code if it would be bad ?
Old 02-19-2014, 03:15 PM   #20
Tyoung68's Avatar
Not necessarily it could be giving a false reading
Old 02-19-2014, 03:21 PM   #21
Tyoung68's Avatar
Old 02-19-2014, 04:46 PM   #22
cliffyk's Avatar
The IAC is not a monitored device, its failure is indicated by the PCM's not being able to control idle speed...
2011+ 5.0 Mustang Low Oil Thread 04TRV6 2011-2014 Mustang GT 113 05-05-2014 07:25 PM
Another oil question lol MC770 1979-1995 Mustang GT 15 02-01-2012 08:14 PM
2000 GT quick question about the Oil.. Constantine 1996-2004 Mustang GT 48 01-31-2012 11:23 AM
oil change 00STANG00 Pre-2005 V6 Mustang 1 10-28-2011 08:16 PM
Oil pressure issues Klinton 1979-1995 Mustang GT 6 09-11-2011 01:52 PM
05:58 PM
